Surrounds: F/X vs small towers
snake1
snake1 Posts: 567
edited September 2012 in Speakers
I've had the idea, from the onset of building a HT/Music system, to possibly use smaller tower speakers in the rear for surrounds Ex. RTi8s. Then I found the FX series for surrounds using the bipole/dipole technology and thought that may be a better route. What are your opinions? Which do you have? Which would you prefer?
At first I ruled it out because I thought tower speakers put off a more 'direct' type of sound. Since having the 12s I have discovered that they have a very BROAD sound! Its seems like sound is coming from the entire wall, not just the speaker fronts. Would towers used for surrounds also put off that broad sound?
I must admit though, 4 towers around the room definately has some asthetic appeal!!! Would definately look beast!
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
  • snake1
    snake1 Posts: 567
    bump
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    VR3 Posts: 29,715
    I would say it may depend on your room.
    If you have a DEEP room and you can position the towers back into the room and maybe on some nice sturdy stands, I would go with towers. The full range effect they will provide will be great.
    I would say then if you are in a shallower room and you will be sitting right in front of the speakers the FX series would be the way to go.
    Polk also has out the FX Wireless ($499.99) - it is essentially like the SDA Surroundbar but for surrounds. You can set it just about anywhere (even has adjustments for this) and will provide multi channel surround use very easily. The best part is you wont need wires and it is already self powered, the whole nine!
    Just my thoughts!
  • snake1
    snake1 Posts: 567
    The room is actually 20'wide x 25'long. The entertainment center is on one of the long walls so... Sounds like FX may be the way to go then. That 20' will fill up quick with our sectional plus the entertainment center. Once I get it all moved in and situated I may take a look at it again. I may be able to put towers further to the sides on the back wall to make up for it not being as deep as it would be facing the other way?
    Since I already have a CSi5 and RTi12s, I want to have the whole matching set for the FX's as well, but thanks for the suggestion VR!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    VR3 Posts: 29,715
    Direct firing speakers can pull off surround duties but you will be surprised just how much better the FX series will sound. The FX series will never draw attention to itself and the sound stage they put out will be large where as DR speakers have these issues in a surround setting.
  • snake1
    snake1 Posts: 567
    I know your right... I just need to get over the 'cool' idea of having 4 towers in my LR O:-)
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    VR3 Posts: 29,715
    If you want to go crazy you can acquire two pairs of towers, run them in parallel, back to back and make your self "bipolar" surrounds! (This would not be ideal by any stretch as you would need a 4 ohm stable amplifier and assuming you are going with the RTi8, your surrounds would be 22" deep!
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Your small towers would be lower than your taller front towers. Kind of odd, if you ask me. I know others have done it. I'm just not a fan of towers for surrounds. YMMV.
  • HTguru1982
    HTguru1982 Posts: 1,066
    I've tried it and I'm a fan. I had to switch to FX series surrounds only because I no longer have the room for large towers. If you can get the RTi8's or whatever towers you choose a foot off the floor, I think you'll be pretty happy. And it will look bad ****.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
