Stereo reciever (for garage)
acmf74
Looking for a sterero reciever that has CD input for the garage. Doenst need to be pristine but clean and works 100%
I'd like to spend no more than $30 dollars.
acmf74@gmail.com
acmf74@gmail.com
Post edited by acmf74 on
Try thirft store, hard to ship anything under 30Hello Kitty am/fm CD player
As aboue shipping will cost u that alone. Check your local CL and u can find something there for sure.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
If you're interested, I have some pieces you can take a look at but I'm in Northern NJ. Could always meet in NYC on Sundays.
I have a pioneer sx780 I'm not using.
goodwill/thrift store even one of the old ones with a record player on top will do rock the garage, as soundfreak said most older receivers are heavy and shipping will be $20+ , I found a silver onkyo txsr303 for $20 locally on ebay , its got very few hook up options but if has enough to watch movies in the 2nd room .
Spend some time looking around and you will score
