New (to me) LS50s
jason32835
jason32835 Posts: 13
edited September 2012 in Vintage Speakers
Whoops, I posted in the main Speaker Forum, I realize now I should have posted here!
I picked up a pair of LS50s last night on Craigslist for $85. When I got them home I realized they have a couple of issues. The main problem is that one speaker is missing all the low end. I tried the simple things like switching sides and double checking my wires, no help.
I took out the drivers and they look good as new, I even swapped speakers for one of them (the bottoms) and the problem didn't move. I'm thinking the issue is with the crossover? I thought about switching the crossover to the other speaker to test it? Are there any other ways to test the crossover? I found the schematic in the sticky, but I don't know what to check for this issue (You've guessed I'm a noob by now).
I will post some pics tonight, but everything looks good as new inside.
Thanks for any help!
Post edited by jason32835 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello jason,
    Probably the first thing to do is to remove the two mid-bass drivers from the nonworking speakers and, at a low volume, try playing each one by directly powering it from your receiver. Each driver should produce sound when given a small amount of power, resist the temptation to increase the playing volume if you don't hear anything. This will determine if you have a driver problem or a crossover problem.
    Let us know what you find.
    Regards, Ken
  • jason32835
    OK great, I will do that tonight. Thanks a bunch.
  • [Deleted User]
  • jason32835
    Ok, took the drivers out and hooked directly to my receiver. They played with no problem.
    Here are some photos for fun...
    Where to go from here?
  • jason32835
    Well.. an update, I put the drivers back in and now they sound great!! I didn't notice the polarity when I was taking them out, I wonder if one of them was backwards? That would tend to screw things up pretty well.
    Anyway, I am in business and that was easy! :) Just need to figure out how to get some bubbly vinyl off the trim and what to replace it with next.
  • 20hz
    20hz Posts: 636
    to kenneth swauger are those drivers in series or parallel ?
    I am thinking maybe they are in series and if one is intermitant when it opens it turns them both off ?
    I got a pair of the ls50's I will probebly take them to my gave " they sound great " .
    I bought them new and was surprised being a audio video speaker they were not magnetically sheilded so a quick call to polk customer service they sell bucking magnets for like ?5? each fixed the problem yes I had a CRT tv than , but thanks customer service great prices great know how plus I got a discount for being a forumn member !!
  • jason32835
    I really love them. They are a little beat up on the outside, but look brand inside. Hopefully they will continue to sound correct, but if not I will check out the wiring.
    Does anyone suggest upgrading the crossovers on these? Any suggestions on where to buy the components?
  • [Deleted User]
    Hello 20hz,
    They are connected in parallel. I'm not sure what caused the initial problem, but it looks as though it has been solved. I believe the LS series was the first speaker series that had the influence of Mark Suskind in the overall sonic development.
    Enjoy, Ken
  • skrol
    skrol Posts: 3,393
    Glad to hear that you got them working. I used to lust after that series in the cherry finish. If it does it again, look for bad solder connections on the crossover or a loose short (ie inductor). I had a couple bad connections on the ones in my RTA-11TL's from the factory.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jason32835
    Great, I will watch out for those as well. Thank you.
  • ken brydson
    ken brydson Posts: 8,783
    Welcome to the LS club. Full 7.1 set here. Bought my 50's new back in 1996 and ran them as my mains until I recently scored some 90's. The 50's are now pulling surround duty. I've got a scanned manual I can email you if you're interested.
  • jason32835
    Wow.. that is some surround setup!
    That would be great, I'd love to have that. I'll PM my email.
  • ken brydson
    Modest setup by a lot of peoples standards. LS90 mains, CS 350LS center, LS/fx's on the sides, LS50's in the rear. Backed up by an SVS 25-31PC+ sub. To ME it's badass... I'll send you the manual shortly.
  • 55LS70
    55LS70 Posts: 184
    Jason, congrats on your score. I bought my LS70's in '95 and after upgrading the crossover caps and replacing the drivers and tweeters (I have to admit I abused them a little and they needed replacing) they sound better than they ever did. The crossover upgrade I think cost me about $45 and made a massive improvement. Again, good score and enjoy.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • jason32835
    Thank you and sounds like a good thing for me to try. Is there a guide that would help through the crossover upgrade??
  • Goldenboy72206
    Goldenboy72206 Posts: 126
    I would love to have a pair of ls90
  • 55LS70
    55LS70 Posts: 184
    Jason,
    At the top of this Forum's "Vintage Speakers" section is a thread that has some Polk Speaker schematics. That's where I found my LS70 schematic and they do indeed have the schematic for your LS50's. It will tell you the capacitor and transistor values you'll need to get. I used Sonic Craft to obtain the ones I needed and had excellent results. There are no doubt other venues that offer these items that probably would provide just as good if not better results. Do a thread search through this forum as there are a couple out that depict replacing caps and transistors. Good Luck.
