The RDO-194 are installed, I am in a state of Grace.
transmaster
transmaster Posts: 428
edited September 2012 in Vintage Speakers
I received and installed the RDO-194's today and in the process found on one of the original MW-6503's in the ?other? 10B had failed which being wired in series killed the the other speaker which ever it turns out to be. Good thing I ordered a second pair of MW-6503 with this contingency in mind. Every thing is installed and blasting. I got bludgeoned over at Audio Karma saying that according to the Polk Audio Forum the RDO-194 is better then the SL-2000, they are sonically challenged The RDO-194 is so much better then the, admittedly 20 plus year old SL-2000 it isn't even close. I now have a brand new pair of Monitor 10B's except for the passive radiators everything has been replaced on both speakers. Below is what I have been listening to with My new Polk Monitor 10B's, I am in a state of grace.,
02 - Cloud Age Symphony, Last Exile - OST 1 flac
02 - A Morning in Norkia Last Exile - OST 1 flac
01 - Road To The Light Last Exile - OST 2 flac
02 - Age Of Loneliness (Carly's Song) Cross of Changes, Enigma (1993)
03 - Dreaming In Colour, The Seduction Of Claude Debussy, Art of Noise
01 - Buffalo Jump, Tatanka, AIRO (featuring Brule') (2005)
07 - Spiritual Awakening, The Return, Bass 305
10 - I Wanna Be a Cowboy (Solar Twins Remix), Boys Don't Cry (1985)
05 - Dreamscape, Dune TV Mini Series OST. Graeme Revell (2000)
07 - Desert Trek, Dune TV Mini Series OST. Graeme Revell (2000)
03 - Main Title (House Atreides), Children of Dune TV Mini Series OST , Brian Tyler (2003)
01 - Fractale, Fractale Original Soundtrack, Souhei Kano, (2011)
02 - Harinezumi, Fractale Original Soundtrack, Azuma Hitomi, (2011)
04 - Nessa no Waltz, Fractale Original Soundtrack, Souhei Kano (2011)
01 - Heavenly Angel, Third Generation, Hiroshima, (1983)
01 - 26 Miles, The Best of the Four Preps, The Four Preps (1967)
05 - It's My Turn to Fly, Titan A-E OST, The Urge, (2000)
01 - Tarkus, Tarkus, Emerson Lake & Palmer, (1971)
02 - Distant Thunder, Distant Thunder, Checkfield, (1987)
The Complete Symphonies (Antal Dorati, Philharmonia Hungarica) (2009, 33 CD set)
01 - Haydn - Symphony 33 in C major - 1 - Vivace
02 - Haydn - Symphony 33 in C major - 2 - Andante
03 - Haydn - Symphony 33 in C major - 3 - Menuetto e Trio
04 - Haydn - Symphony 33 in C major - 4 - Allegro
Radio Station W7ITC
Post edited by transmaster on
  • 20hz
    20hz Posts: 636
    I am thinking about getting a set of those tweeters to replace my silver coils in the moniter 5's supposed to be a nice setup .
    I had a thread posted about amp choices I would like to try those tweeters also .
  • transmaster
    I was forced into it when one of the original SL-2000 failed. The RDO-194 are really very good. One strange thing My Onkyo has the Audyssey automated speaker setup. I doesn't like the left hand 10B now, it reports a speaker error this is the one I just replaced the MW-6503. They sound fantastic but because Audyssey doesn't like the left speaker, where I cannot tweak the speaker balance the left speaker, the one Audyssey doesn't like is louder then the right channel. This sort of thing is a know issue with Audyssey.
    Radio Station W7ITC
  • Mystery
    Mystery Posts: 2,546
    Just change the sound equalizer setting to manual instead of Audyssey in the setup.
    Then you can manually change volume level.
    In my Onkyo, Audyssey is what volume level resets to when the receiver is turned on.
    I can change levels on even Audyssey mode and should be same with yours.
  • transmaster
    It is unclear to me how to go manual. I have turned Audyssey off what else do I need to do.
    Radio Station W7ITC
  • evhudsons
    evhudsons Posts: 1,175
    the rdo 194 will sound even better as it breaks in. enjoy!
    heiney9 Posts: 25,217
    20hz wrote: »
    Get them ASAP, there is no comparison, they are a LOT better.
  • transmaster
    heiney9 wrote: »
    Ditto X 10 :exclaim:
    One of the tracks I played has actual anvil strikes, these are the large anvils you would see in a blacksmith shop. If you listen in person to such an anvil strike it has a distinctive tick, ching, ring sound, even in their "green state" the RDO-194's reproduce this sound better the any tweeter I have yet listened to. H9 about how long is the break in period?
    Radio Station W7ITC
    Im my experience about 200-300 hours. You may experience a change along the way that they sound worse, but they will come full circle again and finally settle in.
  • Dawgfish
    Dawgfish Posts: 2,554
    Sounds like you were listening to Wagner's The Ring.
  • transmaster
    Dawgfish wrote: »
    Right in one :smile: Das Rheingold one of the versions I have properly has the scored 14 anvils on stage.
    Radio Station W7ITC
  • soundfreak1
    soundfreak1 Posts: 3,414
    Ditto on the 194's, in my 12c's they are very nice. Wamt to put a pair in mi 5jr+'s
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • transmaster
    Until I get a 5.1 setup put together Audyssey will remain shutdown. I have things adjusted manually, I don't need some automated wa-de-do-da piece of software do a job I have been doing with mixing boards for many, many years.:biggrin:
    Radio Station W7ITC
  • Dawgfish
    Awesome! I've got a pretty good copy myself performed by the Scottish Philharmonic Orchestra on SACD. The anvil stikes will send shivers up your spine. Good Stuff!
  • transmaster
    Spencer Tunick is putting on Der Ring des Nibelungen and he is saving a great deal of money by not having any costumes, as in naked. Now I am far from being bothered by naked performances after all I have watched high art naked pole dancing in hoochie coochie bars:wink: Somehow watching Brunnhilde, and her 8 sister Valkyries, in Die Walkure belting out Ritt der Walkuren (Ride of the Valkyries) buck naked does not appeal to my artistic side.:frown:
    How very interesting an umlaut (example a U with the two dots above) when typed here gives you a ? mark instead.
    Radio Station W7ITC
    gudnoyez Posts: 8,132
    Glad to hear you like them. I see a pair of 194's coming my way in the near future. I'am assuming the sl 2000s I will replace will gather dust in the junk drawer, from what everyone is saying.
  • transmaster
    No, pack them up in the boxes the RDO-194's come in and go over to Audio Karma and sell them there are people over there that are conviced the SL-2000 is the best tweeter that ever was.
    Radio Station W7ITC
  • nspindel
    nspindel Posts: 5,343
    Heh.
  • canuckaudioguy
    canuckaudioguy Posts: 5
    Actually I think it's the Peerless tweeters that are well regarded over there. And besides, anyone should know that a tweeter over 30 years old is not going to perform as well as something manufactured today. Tweeter technology has come a long ways.
