Dr. Spec spl meter!
dholmes
Hey Dr. how accurant is a Radio Shack meter when its 8-9 years old ? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Couldn't say for sure. If you have a calibrator (a tone generator that fits over the nose of the meter and generates a frequency at a known volume) you would know for sure. I have one and I calibrate my B&K SPL meter that way.
The RS meter itself has fairly cheap components. It is fine for channel balancing and system calibration. It is not accurate at high volumes, nor is it accurate in the very deep bass region. There are bass correction factors for the meter available on line."What we do in life echoes in eternity"
SVS -
Thanks where did you get the meter you have? I bet it was higher than 39.95!!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
It is on loan from work. Yes, the B&K meters are the best in the business. Very expensive. A few $$ thousand new. The one I have still sells for $800 on the open market and its more than a few years old."What we do in life echoes in eternity"
SVS
