subwoofer
wallybee
wallybee Posts: 2
I don't really hear my sub woofer. Is there place to put it that will make a difference ?
I am new to surround sound and could use any advice out there
Thank you!!
I have the polkaudio 6750 system
Post edited by wallybee on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited September 2012
    Hello wally,
    Welcome to Polk's forum. The RM6750 requires some fairly specific connection and setup requirements, can you describe how you have connected the satellites and the bass unit? This will effect the quality and performance of the bass.
    Regards, Ken
  • wallybee
    wallybee Posts: 2
    I connected to my new reciever pioneer vsx 822 which is connect to Bell satellite
    thanks for responding Ken
  • [Deleted User]
    You want to look at the receiver's setup instructions and make sure the sub-out function is turned on, this would be a menu choice. Also make sure the receiver's sub-out frequency is set to 120Hz. This is necessary to match the satellite's low frequency capability. Also the variable low pass filter, on the sub, should be set to the highest setting, turned all the way clockwise.
