F/X speaker placement
snake1
edited September 2012 in Speakers
For those of you with the FX speakers, I guess the effects are the same from most product lines, how did you place yours? Can they go on a back wall instead of the sides? Which mode do you prefer running them for movies, bipole or dipole? Which mode may be best for being behind the listening area?
I'm looking to get some soon and this type of surround speaker is someting I've never dealt with before.
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
    On stands against the back wall.
    Hell, yeah!
    Try both to find out which one you like best.
  • newrival
    From the manual for my FX1000 set:
    SPEAKER PLACEMENT
    The f/x1000 speakers may be placed on any
    horizontal surface capable of supporting
    their weight, or mounted on a wall (see wall
    mounting instructions on page 12). The type
    of surround processor you use and the kind
    of sound and looks you want will influence
    your placement and Dipole/Bipole switch
    choices (Figure 1). Experiment to find the
    right balance of sound quality, room integration and looks that best suit you. Here are
    some recommendations to review before you
    determine the permanent installation.
  • newrival
    And I have mine on my rear wall at the moment, btw
  • tophatjohnny
    I have the FX300i surrounds on stands in Dipole mode, and they sound great. I was thinking bigger may be better, but not in my case. depends on size of room too. BTW they look so cool on stands!! IMO anyway!!
