local pick-up only - RT-1000p (one bad amp) and CS-350
nwohlford
nwohlford Posts: 700
edited September 2012 in The Clubhouse
I am in Arlington, VA right out of DC. These would have to be local pick-up and you would have to take all three. (Actually, you could take the RT-1000p and leave me the center.)
These are not in perfect shape.
All drivers look good on the CS-350. The only real noticeable defect outside of a few minor scuffs is that it is missing the feet.
The RT-1000p have a few defects. The biggest is the sub amp on one turns off after using it a while. From what little testing I did, you can unplug it and let cool down. Then it will work again for a while. I have not used the amp since I noticed it was malfunctioning. I did take it out and did not see anything obviously wrong with it. The dust covers on the tweeters are slightly pushed in (no effect on the sound). They do have some marks but they are not horrible. I can send pictures if anybody is interested.
I might be able to bring them to the Friday of Polkfest. I would have to see if they fit in my car.
You should have at least 100 posts. Preference will be given to the ease of setting a pick-up time.
Post edited by nwohlford on
  • nwohlford
    I forgot I also have the RT FX speakers that I can throw in. If they are not spoken for by next Monday (9/17), they will go to Goodwill.
  • halo71
    halo71 Posts: 4,606
    Dang I wish you were closer to Georgia!
    --Gary--
    VR3 Posts: 28,798
    If these are on the way to Polkfest I will pick these up to auction off for the Githens Center...
    Will mapquest
    VR3 Posts: 28,798
    Yep, I can pick them up for Polkfest or I would recommend bringing them with you and auctioning them off for the Githens Center!
  • nwohlford
    VR3 wrote: »
    That sounds like a good idea. Like I said my car is small, so I will have to check if I can fit all of the speakers in my car. I will send you an email, and we can work out the details.
