Down Sizing Advice
bgw67
Need to downsize speakers, looking for advice on new Polk options. Will be replacing RT1000i's, CS300, and F/Xi50's.
Looking at the Blackstone series, TL3s perhaps, but need in ceiling surrounds. Is there a decent match someone can recommend or point me to a better option. Looking for decent movie sound and some music, all driven by a Marantz SR5005 but will not be played super loud. (I will miss the old set up, loved it).
Thanks!
Thanks!
Post edited by bgw67 on
Welcome to Club Polk!
Polk offers a couple in ceiling compatibles that also have the ring radiator tweeter like the TL3s.
See the products page for 900-LS or 700-LS speakers. There are also some other models for surround sound, again, check product page above. Make sure the speaker has a ring radiator tweeter!
If you are looking at the Blackstones definitely consider the the TL3s. I had the RT1000s for a long time and would consider the TL3s a step up especially for music. Of course, you would need a subwoofer with the TL3s. Make sure to get a sub that can go up to 120 Hz with no issues. (I would look for an upper -3dB of around 140Hz or higher.) For small speakers, they do sound great when set up correctly.
Thanks guys, appreciate the feedback!
