Please ID this speaker
nhhiep
nhhiep Posts: 877
edited September 2012 in Vintage Speakers
I know it's a RT series and it's not RT3. does anyone know? there is no label in the back
Post edited by nhhiep on
  • 11tsteve
    11tsteve Posts: 1,166
    i believe they are RT25i 's....
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    heiney9 Posts: 25,217
    They aren't RT25i's. I have a pair and the drivers are completely different.
  • 11tsteve
    perhaps the best way is for the OP to measure the cab/drivers and compare to the chart? seems to be in this series?
    http://www.polkaudio.com/products/rt15
    Polk Lsi9
    Keces DA-131 mk.II
    Yes, they are either RT15's or RT25's.
    http://www.polkaudio.com/products/rt25
  • soundfreak1
    soundfreak1 Posts: 3,414
    If all else fails pull a driver get the # than tjere should be able to ID prop.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • DaveHo
    DaveHo Posts: 3,536
    RT25. Compare the tweeter on yours to the one in the links. Looks like the 1" tweeter to me.
  • Mystery
    Mystery Posts: 2,546
    RT not R. RT15 and RT25, both have double front ports. See pics above.
    cnh
  • Mystery
    cnh wrote: »
    cnh
    Yes. Good catch. :redface:
    RT15 and RT25 look same.
    May be dimensions will help.
