Surround Speakers for 7.1 Setup with fronts RTiA7
infexXxious
Need suggestion for surround side speakers for my 7.1 setup
Front : RTiA7
Center : CSiA6
Sub : DSW 660Wi
Surround back : F/XiA6
Surround side : ??
Now looking for a good pair of Surround Side speakers i am not looking for something expensive cause the surround
side speakers won't be used most of the time and even if they are used with Pro Logic IIx then only for few effects,
RTiA7 from front and F/XiA6 from the back will look after most of the sounds on my HT
Suggest me something from POLK itself and my budget is nothing more than $250 - 300 ...I am really not looking for
any high watts speakers as i said i just wanted to get that 7.1 effect and my room is quite big ...
So please suggest me guys ....
Front : RTiA7
Center : CSiA6
Sub : DSW 660Wi
Surround side : ??
The surround sides get the workout in HT not the rear surrounds. The rear surrounds kick in nicely for the Pro Logic IIx as you pointed out. Unless it's in 7.1 (not too much to date) they don't get used a lot. I'd put the F/X on the sides & use another speaker for the rears.
pearsall001 wrote: »The surround sides get the workout in HT not the rear surrounds. The rear surrounds kick in nicely for the Pro Logic IIx as you pointed out. Unless it's in 7.1 (not too much to date) they don't get used a lot. I'd put the F/X on the sides & use another speaker for the rears.
Yeah sorry i was confused between Side and rear ...alrite so any suggestions for the rear speakers ? -
The Polk OWM3 & OWM5 look interesting & offer a ton of mounting options. Priced right too. Check them out.
pearsall001 wrote: »The Polk OWM3 & OWM5 look interesting & offer a ton of mounting options. Priced right too. Check them out.
They look really nice + good mounting options .... But will that go fine with Rest of the RTiA series ? -
infexXxious wrote: »They look really nice + good mounting options .... But will that go fine with Rest of the RTiA series ?
From what I understand they should jell nicely with other Polk speakers. Might want to double check w/ Polk but I think they match up well. -
Can you do in-walls?
If not, do you really think Surrounds are needed if you have the FXiA6 in the rear?
I'm very interested in this as my setup is heading in a very similar direction.
Infex, how are u liking the pro660?AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
I have yet to install, but I have a very similar setup, and went with a pair of mint Rti4's.
I got them for $90. I plan on mounting very close to the ceiling, and wanted something smaller and unobtrusive.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
Move FXi A6s to sides. Stay w/RTi A series - go with either pair of referbed RTi A1/3s or, if your SSP/AVR allows a single rear channel, a CSi A4.
Also I find DD and, to a lessor degree DPL, to have quite a bit of side & rear* channel* info. So much so w/out side/surrounds most any title seems 2 dimensional. Granted their output doesn't compare overall to LCR output but still...
* my former set up used a third RTi A1 as a rear center
Shaloam, TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
^^^ A solid recommendation. FXi to side surrounds and RTiA for backs. That's exactly what I'd suggest, too. Similar to my setup and it works very well for me.Move FXi A6s to sides. Stay w/RTi A series - go with either pair of referbed RTi A1/3s or, if your SSP/AVR allows a single rear channel, a CSi A4.
Shaloam, Tony -
Almost like me but im going with A1's for front high's instead of rearHT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P -
Shaloam, Tony
That's what I'm running in the 7.1 except mine are the Rti line not RTiA's.
RTi 10 (Mains), CSi 6 (Center), Rti 6 (Rear surround), FXi A4's (Side surrounds). I'm happy with the sound of these for movies. The Rti 6's are over kill for rear surrounds in a 7.1 set up but they were what I was using for rears in a 5.1 setup before I went 7.1 and added the FXiA4's.
Stick with something in the RTi A line for rear surrounds, you can't really go wrong with that choice.
My .02,
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
