Fix it or forget about it?
audiocr381ve
audiocr381ve Posts: 2,588
edited September 2012 in Vintage Speakers
I installed Larry's rings from my 2B's (rings for the drivers) on my new Monitor 5B's and ran into some problems that are beyond my skill level.
This happened to pretty much every hole I drilled:
I was able to put the speakers in and they were/are very secure, but it just bugs me knowing that the holes are cracked like that.
If it doesn't effect the sound quality at all, then I'll just try and forget about it, but if one of you more experienced guys thinks it will effect the sound, then I'll deal with it. So far I can't hear a loss in quality and the speakers are very secure.
Post edited by audiocr381ve on
    VR3 Posts: 28,784
    I would think structurally you would be fine... as long as you use good driver seals I would not worry about it
    nooshinjohn Posts: 25,464
    This is not that hard to repair with a bit of wood filler on the affected holes. I would also use Armacell here as the material expands where the extra gap in the seal would need to be.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    You might try some epoxy just for a little extra strength,if done neatly could work.
    This is F1s gig.
    VR3 Posts: 28,784
    I would think since the driver is being achored to a steel ring... the wood is not offering any support what-so-ever anymore...
  • audiocr381ve
    I should have mentioned mine were worse than the picture shown which I stole from another thread. The metal insert (not sure if it's the correct term) for the ring is completely exposed. I've never used wood filler, but it's probably a good time to learn. I remember checking for armacell at a local Home Depot once and they didn't carry it. I do see some different items on the website. This looks to big: http://www.homedepot.com/h_d1/N-5yc1v/R-100539553/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=armacell&storeId=10051#.UEa7OKSe4e0
  • audiocr381ve
    VR3 wrote: »
    That is what I thought. The metal insert took that role right?
    VR3 Posts: 28,784
    As long as the ring does not "wiggle" the wood is doing nothing at the mounting point... the strength of the mount is from the ring pressing against the MDF and the woofer basket frame to the MDF -
    As long as there is a seal... should not make any differences...
    Where in SoCal are you... I have some you can have.
  • audiocr381ve
    Ahh thanks John, but don't worry about it. I'd like to have some extra anyway and don't mind ordering a full roll of the stuff. I'm down the street from San Diego State University btw.
    You coming the the SoCal meet?
    F1nut Posts: 50,755
    Use wood epoxy to repair the damaged areas. It looks like a biege Tootsie roll. Home Depot carries the long cure version. Slice off a small piece, knead it together using a little water on your fingers for lubrication and press into place. Try to shape it as best as possible right away, then let it cure for 24 hours before final shaping with a chisel, sandpaper, file or whatever.
  • audiocr381ve
    Thanks Jesse. Should I leave the ring in to help shape it?
  • audiocr381ve
    Looks like their is nothing official yet on the calendar for it? I may be able to get away for an evening. My wife is on maternity leave with the newborn, so it just might work out although I'm working all day on the weekends.
    F1nut Posts: 50,755
    Yes, but be careful to not get any wood epoxy in the threads.
  • audiocr381ve
    Gotcha, thanks dude.
