Yamaha or Pioneer??
Ripping Rudy
Hi Guys,
I currently have a Yamaha HTR-5650 (same as an RX-V540) which I purchased from the Future Shop here in Ontario. I got it for $549.00 CDN + a "free" pair of Quest QB5 bookshelf speakers. The reason I bought the Yamaha is the sales guy told me they were awesome and I wanted the 2 free speakers so I could spend more on my mains, centre and sub. Anyway, I can pick up the Pioneer VSX-D912K at another store for $499 CDN and it has won some awards and got glowing reviews all over the place.
I wonder if anyone has any advice on this? I have about 15 days left to return the Yamaha so any input is appreciated!
Thanks,
Chris
Thanks,
Chris
Post edited by Ripping Rudy on
If you're happy with the sound of your Yammi, keep it. I wouldn't bother with Pioneer unless it's their "Elite" line. Find a store where you can do a demo. If I were you, I'd keep on using the Yammi and save up some cash for a few years so I can upgrade to a great high end receiver or maybe seperates. I doubt there will be that much of a difference in the two receivers at $500 a piece.
Maurice
