What center channel
Crazysikh
Crazysikh Posts: 4
edited September 2012 in Speakers
Hi i have rti 10'sfor fronts and rti 8's for front wides and rti 8 for surronds and rti 6 for surrond backs now i need to upgrade my center and dont know what to buy please help. Oh and for amp i have a onkyo
  • B Run
    B Run Posts: 1,888
    A Csi5.
  • falconcry72
    falconcry72 Posts: 3,580
    Or a newer CSiA4 or CSiA6
  • Crazysikh
    Crazysikh Posts: 4
    i have the cs10 but thinking its time to upgrade so im taking the csia6 is alot better or what is?
  • B Run
    B Run Posts: 1,888
    The Csia6 and Csi5 are pretty similar and either one will work, the only reason I suggested the Csi5 was too cosmetically match all your other speakers and finish off the set. If you have the room go with the 5 or 6 over the Csi3 or Csia4, you'll be glad you did.
  • jkg123
    jkg123 Posts: 114
    CSi5 - it will match perfectly, plus you can save some coin over the CSiA6
  • jkg123
    jkg123 Posts: 114
    Sounds like it will be an amazing system
  • Crazysikh
    Crazysikh Posts: 4
    Thanks it is starting to sound good. One more question my monster power center the hdp1800 do u keep that on all the time
    ? Thanks
  • jkg123
    jkg123 Posts: 114
    Yes, its essentially a component surge protector....would you constantly unplug your tv when you are down watching it?
  • jkg123
    jkg123 Posts: 114
    plus, does it not have green power?
  • Crazysikh
    Crazysikh Posts: 4
    no it does not have green power
