RTA 12 Value
restanim
Available for $200 looking like in excellent condition. With stands and the sideways mounted Peerless tweeter. Should I go for it?
Mike
Mike
polkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
Currently Own:
Previously Owned:
Post edited by restanim on
i picked up a pair of RTA 12's off craigslist about 2 months ago. i have a pretty steep learning curve to travel concerning the technical aspects of speakers, (getting a LOT of help from guys on the site) but i know what i hear, and these are the cleanest speakers i've ever heard. for 200.00 i grab them in a heartbeat. i love mine
"The symbol is not the reality" -
Those sound like the first in the RTA 12 series. 12B's and 12C's are more advanced, with a better Xover design and much better imaging.Having said that, those are no slouches.
IMHO $200 is a bit high if they've had no work done on them since new, i.e. tired old Xover parts replaced. Those speakers are 30+ years old. I'd offer him $100 and pay up to $125."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
+1 DRUMMINMAN maybe 150 if really clean. If they are your first rta series speakers u will be happy .Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
i paid 140 for mine, and they are worth every penny."The symbol is not the reality"
Thanks guys.
Here are some pics:
What do you think?
Mikepolkaudio
Currently Own:
Previously Owned:
SRS 1.2TL Sept/2009 to Sept/2015 -
Tjey dont look too bad.the market iny area is soft! 100.00 would be a good buy, over that just depends on how bad u want them.never heard tje reg. 12'S only the b and c models.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
They look brand new!
I would definitely audition them, get a bit of history on ownership, what have they been driven with, remove the grills and have a look at the drivers.
30+ year old speakers can look great but still have issues that, though fixable, would affect the price."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Thanks for all the suggestions, but I have decided not to pursue these. If anyone is interested, the link is provided below.
No affil.
Mike
http://syracuse.craigslist.org/ele/3245973260.htmlpolkaudio
Currently Own:
Previously Owned:
