TSi100 as computer speakers
JustinChiu24
JustinChiu24 Posts: 39
Hi all, this is my first post on this forum. I am also new to this audiophile world and taking my baby steps.
I am going to buy a TSi100 and use it as my computer speakers, since those speakers are passive, I will need an amp.
My question is, if I buy a PSW110 active sub-woofer, can I hook my TSi100s to the sub-woofer? If I do this do I still need an amp?
Please help me out ASAP, all comments on the performance of these speakers are welcome as well.
Post edited by JustinChiu24 on
    tonyb Posts: 33,068
    edited September 2012
    In short, yes. The speaker level connections on the subwoofer are not powered by the subs amp.
  • JustinChiu24
    So what you're saying is that I will still need an amp? Sorry, I'm a bit lost here.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Welcome! Yes, you will need an external amp to power the speakers.
    Regards, Ken
  • jimbo1421
    jimbo1421 Posts: 772
    My review is here: http://www.polkaudio.com/products/tsi100#reviews
    For best results I would suggest moving them further away than monitor distance from your ears.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • JustinChiu24
    Do you guys have any suggestion for a nice amp that can provide 100W that won't break the wallet?
    @jimbo1421 How far would you suggest it to be?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    It's best to avoid posting the same question multiple times, better to just stick with one thread so that others can follow along and replies are all in one place.
    http://www.polkaudio.com/forums/showthread.php?135698-TSi100-as-computer-speakers
  • JustinChiu24
    Sorry, Assimilated. Didn't realize that this will cause difficulties.
  • transmaster
    transmaster Posts: 428
    You can do what I have done for several decades on the line out either digital or analog from you sound card, or on the board sound run a line out to a receiver of your joice. There are numerous choices Sony, Denon, Yamaha, Onkyo, Pioneer, Marantz, etc. Check out this link http://www.crutchfield.com/g_10420/Home-Theater-Receivers.html?tp=179 I always suggest Crutchfield because I have been a customer of theirs for 39 years. These are 5.1, 7.1 Home Theater receivers. None of them have to be used as a surround sound system they will do stereo just fine but you have the option should you want to. Depending on which model you get you can add DLNA, (which connects the receiver to the PC via ethernet) Net streaming services such as Last FM, vTuner, Spotify, etc.
    Radio Station W7ITC
  • jimbo1421
    Try to set up an isosceles or equilateral triangle with your head at the apex. 5 feet or more if you have the space. At normal listening levels for an office (not rocking out) I didn't mind them being closer.
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • JustinChiu24
    Hmm, I see. Someone told me that TSi100's are not designed for near-field listening, so now I'm thinking of getting a Swan instead, which one would be the best? Budget can go as high as 650USD. I'll prefer a 2.0 and an extra sub. I'll prefer an active speaker, so unless their's a very good reason, I'll most likely not choose the TL3.
