Question - Volume vs. Media
stretchl
stretchl Posts: 1,334
edited September 2012 in 2 Channel Audio
Should there be a difference in the effective volume of sound that originates with different media?
For instance - To get the same speaker volume, I have to turn the volume knob on my pre-amp significantly higher when the source is vinyl than I do when the source is a digital file streamed though my SBTouch.
Thanks.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
  • cfrizz
    cfrizz Posts: 13,415
    Yes this seems to be normal with different media, and it is also the case even with digital media. I find that I have to turn up the volume on some of my older cd's but when I put in a newer cd I then have to scramble to turn the volume down. Basically it all comes down to how it was orignally mastered.
  • stretchl
    Thanks, cfrizz.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • falconcry72
    falconcry72 Posts: 3,580
    cfrizz wrote: »
    ...I have to turn up the volume on some of my older cd's but when I put in a newer cd I then have to scramble to turn the volume down. Basically it all comes down to how it was orignally mastered.
    On a lot of my stuff, I find that the "quieter" cd's, that I have to turn up, sound better. Like The Cars; Shake it Up, for instance.
  • stretchl
    Interesting.
    I still think vinyl sounds better, minus the cracks and pops, and that's what I have to turn up.
    - Isaac Asimov
    Hi-Fi
    Visuals
    tonyb Posts: 33,028
    Aside from differences in recorded material, each piece of gear has different impedence, or mismatched in a way, that accounts for different volume levels. You need more/less gain to get the same volume level between gear because of it.
  • stretchl
    Just came across this insert to a MFSL version of Quadrophenia. Seems to answer my question -
    - Isaac Asimov
    Hi-Fi
    Visuals
  • brgman
    brgman Posts: 2,859
    stretchl wrote: »
    Interesting.
    what phono pre do you use? that can play a huge part of vinyl needing more on the volume "button"
    any media affects this for me.i have many going thru the SB that vary in how the original recording was done.some need to be at 4 and some at 6.
    it's when you need 11 that it becomes an issue.
    I’M OFFENDED!!!!
  • newrival
    newrival Posts: 2,017
    As Tony stated impedance can be a cause. Also, if I'm not mistaken, Squeezeboxes utilize quite a bit of gain wide open. Phono pres can be all over the map on gain, but I would bet they are quite a bit lower than a SB.
