~200 dollar preamp
youra6
youra6 Posts: 11
edited September 2012 in Wanted (WTB) Classifieds
Hi, ~200 dollar budget. Solid State, tube, doesn't matter. I do like that vintage 70's gear though
Integrated stereo amp is fine too!
Thanks. Can pay with PayPal or Amazon Payments.
My heatware:
http://www.heatware.com/eval.php?id=73174
I am also the same youra6 on overclock.net
Post edited by youra6 on
  • zingo
    zingo Posts: 11,258
    edited August 2012
    My local Craigslist seems to always have some good preamp for the price range.
  • youra6
    youra6 Posts: 11
    edited August 2012
    zingo wrote: »
    I'm living in a smaller city so the pickings are never too high. Some guy was selling a GFP 555 for 150 dollars, but that is way too high of an asking price for an older and mediocre Adcom unit.
  • onebadchad
    onebadchad Posts: 364
    edited August 2012
    I have a parasound CA 250 with pre outs. 100 plus shipping
    Hello Kitty am/fm CD player
  • youra6
    youra6 Posts: 11
    edited August 2012
    onebadchad wrote: »
    Isn't that Parasound unit a power amp?
  • onebadchad
    edited August 2012
    It is, but has an excellent Pre-amp section, and pre outs, so you dont have to use the power section. And about the same size as most pre amps.
    edited August 2012
    Welcome to Club Polk!
    In that price range I'd look at an old Hafler or maybe one of the Onkyo P-3XX series. Should be able get either for well under 200 and have a decent pre for the price. OBChad also has a decent unit and he is correct about that. No reason you can't use that as a pre alone.
    Good Luck!
    cnh
  • youra6
    youra6 Posts: 11
    edited August 2012
    cnh wrote: »
    Good Luck!
    cnh
    Awesome. Thanks for your replies gentlemen. I'm definitely consider the Parasound, they make some good stuff.
    Would the unit need to be recapped/serviced anytime soon?
    What about a Dynaco PAS-3 tube pre at around that 200 dollar price range? It appears to be a stock one. I know it is highly regarded, but can anyone give me a more detailed assessment?
  • onebadchad
    edited August 2012
    The Parasound is mid 80's it works fine now, It doesnt need capped now, but may at some point. Your looking for 100.00 preamp, I dont think your gonna find something new thats worth a crap in that range. I also have an Oknyo P-301 thats a lot newer with remote and books. works perfect for 100 plus shipping.
    mhardy6647 Posts: 35,263
    edited August 2012
    ... or you could consider investing 99 smackers, some batteries and a bit of solder...
    http://www.bottlehead.com/store.php?crn=220&rn=438&action=show_detail
  • onebadchad
    edited August 2012
    12ax7?
  • youra6
    youra6 Posts: 11
    edited August 2012
    onebadchad wrote: »
    Well technically my budget is in the 250 range.
  • deronb1
    deronb1 Posts: 5,021
    edited August 2012
    What amp are you pairing the pre with? Could make all the difference in the world.
  • youra6
    youra6 Posts: 11
    edited August 2012
    deronb1 wrote: »
    Either my Adcom GFA-535, or my Emotiva UPA-2
  • deronb1
    edited August 2012
    Unless you are going to go with a tube pre, you might want to consider going with the same make pre as the amp. I just went through this, pairing an Adcom GFP 565 with a Kenwood Basic M2 amp. Sounded good enough, but I think there was an impedence issue as I could not turn it up past 9 o'clock without it getting crazy loud. Got an Adcom GFA 555 and made a world of difference. Now I hear EVERTHING and am quite frankly freaked out by it. :eek:
    My point is that getting into seperates only exponetiates the possibilities of sound (good or bad). A safe bet is going with common manufacturers and then tweaking it from there. The guys that make this stuff do it for a living and they want people to buy THEIR stuff. They spend countless hours and dollars refining their products so they sound good TOGETHER. For the most part it does. This is not to say that you can't add a different piece and it won't sound good, but for what you are asking, this is what I am saying.
    edited August 2012
    deronb1 wrote: »
    Unless you are going to go with a tube pre, you might want to consider going with the same make pre as the amp. I just went through this, pairing an Adcom GFP 565 with a Kenwood Basic M2 amp. Sounded good enough, but I think there was an impedence issue as I could not turn it up past 9 o'clock without it getting crazy loud...
    That's not impedance, that's gain.
    edited August 2012
    youra6 wrote: »
    Any of the pres in my post above will sound OK with either of those units. I've used an Onkyo P-304 on an Adcom GFA-555 with good results. And I've heard Hafler's with other Adcoms that sound good as well. Parasounds would also work. There are enough people using those here?
    Happy hunting.
    mhardy, are there tubes in your pic above? I'm not sure--there seem to be two (maybe my eyes are going bad)? Never mind, I see the tubes in the kit...what was I thinking?
    cnh
    edited August 2012
    The Bottlehead Quickie preamp uses two very vintage low-voltage tubes (3S4 - an old battery portable radio tube) in its single gain stage. It's a low gain preamp fo' sho' - it is also simple, cheap, infinitely tweakable, all Class A (duh) and it has a noiseless DC power supply.
    http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=3S4
  • youra6
    youra6 Posts: 11
    edited August 2012
    Appreciate the help gentlemen.
    I'm not comfortable with a DIY kit since my soldering skills are iffy at best. The last thing I want is a 100 dollar
    door stop.
    I have looked at the GFA 565 as a preamp that may fit my budget. I've looked at many others as well.
  • deronb1
    edited August 2012
    youra6 wrote: »
    door stop.
    I am using the GFA 565 right now. Great pre and very flexible. Unless you are using an Adcom amp, however, there may be an impedence issue that may not allow you to turn the volume knob up much before it starts getting VERY loud.
    Learned that here, on this very forum. This is THEE (like THEE Ohio State University) place to learn stuff that is all audio. :cheesygrin:
  • youra6
    youra6 Posts: 11
    edited August 2012
    deronb1 wrote: »
    Really? I'm a huge Bucks fan myself. Meyer era starts tomorrow, cant wait. Unfortunately, I'll be going to Camp
    Randall and watch the Badgers play tomorrow.
  • weitrhino
    weitrhino Posts: 34
    If you like the vintage look, why not consider the Carver C-1? It fits your price range, for sale regularly, vintage 80's design, very tweakable, and it's a proven performer with a phono stage.
    _________________
    Carver Tube Monoblocks
    Sunfire Classic Vacuum Tube Control Center
    Carver Amazing Platinum Speakers
    Oppo BDP-93
    Carver TX-11b
  • rtart
    rtart Posts: 852
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • chumlie
    chumlie Posts: 8,658
    rtart wrote: »
    Somebody stole that one. Didn't think it would last long.
