Which speaker for front high?
I currently have RTi A7's as main and was wondering which speakers I should use for front high's. Right now I'm looking at TL1 or 2 and the OWM3's. I feel as if the RTi A1s are overkill for this and I don't really want to spend that much on front high's. I would like to keep them on the small side.
Thank you :cheesygrin:
HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P
actually im using monitor 30's for heights and plan on upgrading to rtia1's or rti4 heights should be timbre matched imo alsoI currently have RTi A7's as main and was wondering which speakers I should use for front high's. Right now I'm looking at TL1 or 2 and the OWM3's. I feel as if the RTi A1s are overkill for this and I don't really want to spend that much on front high's. I would like to keep them on the small side.
Thank you :cheesygrin:Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels -
I am using Polk RM 6750 Satellite speakers for front Highs & surrounds. Fronts are RTi A7 & center CSIA6. All are doing good
