new to me 5JR
11tsteve
11tsteve Posts: 1,166
edited August 2012 in Vintage Speakers
scored a pair of 5JR this week on ebay for $30. and while they are rough around the edges a bit, i find $30 to be pretty cool.
the have some surface scratches and such. and since i have "freshened" my 11Ts and know the potential, i hear that the 5JR's could use a little updating. that being said, they sound pretty darn good. i already have a PSW-10 sub which in my room would be necessary, but that being said, i am very impressed with the size of the soundstage they have and for their age how even they sound.
i would really like to refinish my 11T's so i bought these to experiment with removing the vinyl laminate and re-applying veneer for practice, but i now realize, in the spirit of club polk, that i will surely end up taking these as far as i can with updates.
wallet be damned!:cheesygrin:
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Post edited by 11tsteve on
  • Big Dawg
    Big Dawg Posts: 2,005
    edited August 2012
    I love me some 5Jrs. Lotsa beautiful sound, small(ish) box. Do yours have the passive?
  • 11tsteve
    edited August 2012
    yup... and looks like SL-2000 though i haven't opened anything up yet.
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    edited August 2012
    couple of quick pics
    5L.jpg 165.5K
    5R.jpg 104.2K
    Polk Lsi9
    Keces DA-131 mk.II
  • gwg_97
    gwg_97 Posts: 332
    edited August 2012
    Wow! Those are nice. If I were you I would spend a little money on some new caps and resistors instead of veneer. Veneering those puppies is far from easy and you can spend a huge amount of time and money
    "learning". Then again, I'd you are really into learning and have the time, go for it.
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • skrol
    skrol Posts: 3,393
    edited August 2012
    They look nice with the 11T's. Same style cabinets.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • 11tsteve
    edited August 2012
    gwg_97 wrote: »
    they photograph well, but the sides are fairly scarred. crossovers will be done..... i used Sonicaps and Mills in the 11T's and was thinking of trying Clarity and possibly Mundorf for these.
    I realize refinishing will be a lot of work. but i usually have a winter layoff and am looking for a project. obviously, no big hurry...
    Lasareath wrote: »
    One day I need to find a pair of 5Jr+'s, Almost bought a pair in 1987, I wish I did :(
    turns out after doing some research here, it would seem that is what these are.
    Polk Lsi9
    Keces DA-131 mk.II
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    I did a pair using clairty SA caps and resistors, 14ga ofc wire, new terminators,binding posts, dynamat and they are quite amazimg for a bookshelf. Dropped about a duce into them but the results were worth it.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • 11tsteve
    edited August 2012
    very nice! what tweets are in yours? and also what stands are you using? i plan on doing most likely about everything i did to the 11T's with the exception of rings but not in a major hurry, just as i can afford. i am just climbing out of the rabbit hole i fell into getting my meager 2 channel system up and running...
    also curious who modded and restored you 1200?
    Polk Lsi9
    Keces DA-131 mk.II
  • StuartB
    StuartB Posts: 87
    edited August 2012
    I recently upgraded a pair of 5Bs. I had a blast doing it. I used Clarity PX in tweeter circuit and Solen in the woofer section. I used a Mills resistor. I upgraded to the RDO tweeters, and added Armacell gaskets and Hurricane nuts as well. The sum of all that was a significant improvement in performance. I have the urge to go to wood veneer as well. Hope you keep us current if you go for it.
    Good luck.
  • sda2mike
    sda2mike Posts: 3,131
    edited August 2012
    h9 will chime in soon...he has some 5s that he upgraded
