Focal Electra 1027S
zingo
zingo Posts: 11,258
edited September 2012 in Speakers
Has anyone heard the Focal Electra 1027S speakers?
    pitdogg2 Posts: 27,823
    edited August 2012
    yep ...I heard I can't afford them.....:rolleyes:
    sorry no can help here...
  • erniejade
    erniejade Posts: 6,321
    edited August 2012
    Great sounding speaker but, picky on what you put behind them and wire. Better with warmer but fast equipment I should explain. tube type pre SS amp.
    edited August 2012
    erniejade wrote: »
    Agree completely. I heard these a while back, can sound "great" with proper amplification combo, but "flat" and less dynamic unless you get the right gear in play!
    cnh
  • zingo
    zingo Posts: 11,258
    edited August 2012
    Just demo'ed the Be version of these speakers, and they sounded good (electronics were all Halo). $9k good? No ma'am, but musical and detailed with great imaging. I kept thinking they sounded a little vailed or rolled off, but my eye is used to horn, so I must be biased.
    @@@@@ Posts: 114
    Which one is better speakers for music only focal electra 1027s or focal chorus 836w?
  • zingo
    zingo Posts: 11,258
    I would go for the Electra 1027S if you can get the clearance price. $3500 for a pair of those is a great deal.
    @@@@@ Posts: 114
    Isn't it that evrything inside the 1027s is the same as 836w except for the tweeter? In fact, 836w has three woofer more than tow from 1027s
