line level convertor
kelley
kelley Posts: 287
edited October 2003 in Speakers
Has anyone ever used one? Mainly on a lower end ht receiver for the surround channels that don't have pre-outs?
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Post edited by kelley on
  • scornful
    scornful Posts: 272
    edited October 2003
    I've used them in car installs, but I have never seen one for HT. I'd be very careful that these are supposed to be used w/ HT. I doubt they will like the power of a HT receiver if not approved. Who knows you might screw up that amp you're trying to supply.
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
    InFocus 4805 ~100" Screen
  • kelley
    kelley Posts: 287
    edited October 2003
    I've seen the cheaper car versions but I was hoping there was one at Radio Shack or somewhere for home use. I was at a crossroads on whether to finish my speakers or upgrade to a pre/pro and decided to go the speaker route. I'm going to come up with a big power difference between the front and the rear and it will be a while before I can put some cash down on the pre/pro.
  • scornful
    scornful Posts: 272
    edited October 2003
    I wish you the best of luck on the line converter. Maybe someone here will pop in with some info for ya. What kinda amp/receiver do you have? Maybe some info will generate some answers....
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
  • kelley
    kelley Posts: 287
    edited October 2003
    I have a Denon 1802. I am running 3.1tl's for the front bi-amped with my Denon monos for 410wpc. I will also have 2 CS400 biamped at 200 wpc each for the center and the rears will soon be fx500/500i running off of the 1802 at a low amount of power(I'm too drunk right now to go dig out the manual)! But I'm sure it's well below 100wpc. Just can't afford the $1200 it would take to get the B&K 30/Rotel 1066 I'd like at this time.
  • scornful
    scornful Posts: 272
    edited October 2003
    Oops... that was external inputs I looked at.
    Denon 3802
    B&K 7270
    Outlaw ICBM
    Behringer DSP1124P
    Samson S1000
    SVS 20-39CS+ (x2)
    RTi150's
    CSi40
    FXi30's
    RTi38's
    Win Vista HTPC
