Two Subs?
gce
gce Posts: 2,158
I have my new sub ordered (SVS PC12-NSD). I'm replacing my Klipsch that is on the front stage right side. There is no room for the SVS up front so its going on the rear stage left side. Got the cable run and I was thinking why not leave the Klipsch hooked up and dial in two Subs, the recever has 2 sub outs.
So my question is would this sound good or should I just take the Klipsch out of the picture and let the SVS do the job?
Anaheim Hills CA,
Post edited by gce on
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2012
    Bass response is very room dependent, and every room is different, so there's really no right answer. Dialing in 2 subs is definitely more tricky than 1, but that doesn't mean it won't be beneficial.
    I would setup just the SVS by itself first, to see what it's capable of, and then see if you can improve things by adding in the Klipsch. If you go straight to running both, it may sound better than the Klipsch by itself, but not as good as the SVS by itself, and you wouldn't know it.
    Experiment and see what works in your room. Good luck!
  • chris23120
    chris23120 Posts: 95
    edited September 2012
    I would try it out. Technically i run 6 subs..LOL Although the center channel sub is crossed over at 60hz and the left and right towers subs run on the Large setting L/R front on the tuner so only 3 run on the LFE. I have a large room and find that it sounds much better with all the gains low but having a huge amount of headroom so its amazing when some random bass hits during a quiet scene in a movie and your drink moves.
    Samsung UN55C6500 55" LED
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    Polk Audio PSW1000 5.1 sub
    Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
  • -FROG-
    -FROG- Posts: 31
    Gotta experiment and play around with real time audio tests.
    VR3 Posts: 29,521
    If your SVS peaks out at 110db and your Klipsch at 105db, the Klipsch is doing nothing...
    I would sell the Klipsch
  • spock 2054
    spock 2054 Posts: 163
    gce wrote: »
    Your setup, as far as sub placement is identical to mine. Try it. I have my Velodyne DPS 12 rear left and the Polk PSW110 front right. Sounds fine after running Audyssey on my Onkyo 809. Have you run YPAO on your receiver with both subs yet? That SVS sub is a odd, but good looking sub. Ever thought about two of those?
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • Airplay355
    Airplay355 Posts: 4,298
    I've heard a good way to put too subs in a room is to place the first sub where you want it (or where your wife lets you put it). Then walk around the room to find the spot where the bass is quietest and stick the other sub there.
  • -FROG-
    -FROG- Posts: 31
    VR3 wrote: »
    You don't think the second sub may be a solution to covering dead spots, depending on how "live" the room is? My Theater room is not crazy big, but the back side of it runs into 2 more rooms and an open pathway to another few rooms. Not to mention all wood floors... I had two 12's up front which "should be" more than enough but experimenting with placement, the bass still ended up in all of the other rooms. I got my hands on a Cerwin Vega down fire 15" and set that in a 3rd corner and it helped tremendously! Recently I sold the two 12's up front and got my hands on a set of Cerwin Vega 15's and the problem is solved with the dead spot where I sit. The only down side is it has knocks stuff off the walls and breaks them. :( I guess my point is, maybe the second sub would benefit in some way depending on the room setup?
    *This coming from a guy that once had two 18" subs in his car, so the demand is high for extreme bass*
  • gce
    gce Posts: 2,158
    Tried the 2 together and then unplugged the Klipsch. I now have more room in my living room because the Klipsch is out of the picture. The SVS kicks ****...I'm very happy with it!!! :cool:
    Anaheim Hills CA,
  • gce
    gce Posts: 2,158
    Now I know my bass is setup just right. Listening to some music and my wife asks me "Do you think there's to much bass" I say "No, why" she says "cuz I can feel it". :mrgreen:
    Anaheim Hills CA,
  • -FROG-
    -FROG- Posts: 31
  • 20hz
    20hz Posts: 636
    Ps my wife does the same thing " why does it have to rumble so much"
    I always ran 2 subs first it was one under each main as a speaker stand then I moved it to the cornor and new DIY sub was much lower and deeper than the 15" dayton quatro but I still run it at a lower gain to add fill to my room .
    The Big sub was in the cornor and the15" on the side of the tv I was watching the movie stargate the scene when the spaceship takes off I went up there to adjust position on my center speaker so I was standing between the subs well the bass hit I felt the floor wave and my stomach turned , it was intense .
  • -FROG-
    -FROG- Posts: 31
    20hz wrote: »
    You should do a frequency sweep and see where the resonate frequency is! I have a cool "Function Generator" app on my phone and LOVE sweeping subs! :eek:
  • chargerman426
    chargerman426 Posts: 419
    Really depends on the subs. I had an Outlaw sub than bought an SVS. The Outlaw couldn't keep up with the SVS so I got rid of the Outlaw.
    If life had more tubes it would be a lot smoother.
  • dorokusai
    dorokusai Posts: 25,576
    I'd say based on the information provided, stick with the SVS only and sell the Klipsch. If you have two subs in different areas you are creating more problems, as mentioned above and unless you're getting some room correction gear or software, it will get worse. It's just not that easy and even harder to incorporate two different subwoofers into the same room without electronic help.
    The SVS is more than capable of handling the room, go with it.
    Mark
  • McLoki
    McLoki Posts: 5,231
    edited October 2012
    If you decide you need more bass, sell the klipsch and get another SVS. (same as what you have) If you are fine with the bass you have, move the Klipsch to another system or sell it.
    Either way - dialing in 2 different subs is a nightmare. with 2 of the same subs, you can choose a 6db gain (putting the subs together) or a 3db gain (moving the subs apart - but an overall smoother room bass curve)
    Enjoy,
    Michael.
  • ss1
    ss1 Posts: 13
    edited October 2012
  • 20hz
    20hz Posts: 636
    edited October 2012
    I got a strke disc its basically a freq generator , how would I know the resonate frequency ?
    I have done 20-100 hz , I just do it to check where the db drops at 20 hz , I think it was 9 db .
    Its a true sub !
    -FROG- wrote: »
  • 20hz
    20hz Posts: 636
    edited October 2012
    now I put all subs in the cornor with one amp feeding the set ( its four 12" in a isoberic clamshell cabinet )
    I had dialing in problems before but hopefully all cornor loaded solves it .
    As long as the window wont break above it .
  • mwk455
    mwk455 Posts: 219
    edited October 2012
    let us know what you do .
  • SugarmillMan
    SugarmillMan Posts: 175
    edited November 2012
    mwk455 wrote: »
    Ditto. Getting two subs into a living room or family room space is sometimes a tough one. The WAF factor is going to be a tough sell in most cases. With smaller subs you may fair a little better but for larger subs, it's a challenge.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • chumlie
    chumlie Posts: 8,658
    mwk455 wrote: »
    See post #10 & 11.
  • be83663
    be83663 Posts: 192
    I would recommend two identical subwoofers one next to each front speakers. Definitive Technology's BP7000 speakers, $2,500.00 each is what every speaker companies are striving to make after; and those speakers have a built in subwoofer, one for the Left speaker and one for the Right speaker. If you have a bookshelf or 2-way or even 3-way Front Speakers that you need subwoofer for, then imitate what the BP7000s are doing and put one subwoofer next to your left front speaker and another subwoofer next to you right front speaker. It will be well balanced that way for a much better theatrical sound!!!
  • gce
    gce Posts: 2,158
    Thanks for all the help and suggestions guys. I've had the SVS for a month or so now and found out that's all I need in the room it's in. All I can say about this sub is it kicks **** when needed and puts out clean tight bass the other times.
    Anaheim Hills CA,
  • Face
    Face Posts: 14,340
    be83663 wrote: »
    Not true at all.
    Toolfan66 Posts: 18,147
    Face wrote: »
    Not true at all.
    +10000000000
    I have two subs in my HT, one in the back and one to the side of my room, I have them dialed in so good that you can not tell where the subs are in the room when being played..
    With that said I don't think I would want to tackle two different sub manufactures. not saying it can't be done cause I don't know, I'm just to anal when it comes to putting things together. I want it all to match not just in sound but aesthetics as well..
  • newrival
    newrival Posts: 2,016
    Two subs will always be better than one (given comparable performance) to help smooth frequency response.
  • newrival
    be83663 wrote: »
    This is ridiculous. Subwoofers within the cabinet are space saving compromises and have been utilized long before the bp7000.
  • newrival
    It seems to me there are few people commenting that actually understand the reason for multiple subs. I'm even surprised by doro's comments, considering the regard I hold for his experience. If the subs are the same delivery type (sealed/ported/bandbass/IB/whatever) and are of at least decent quality, you are much better off having more than one. Nearly invariably.
    Two subs aren't for getting you "more sound" (unless they are benefitting from coupling, and you need the extra headroom), it gets you smoother sound. Multiple subs is about frequency response smoothing and combatting room nodes. And, no, the subs don't have to match, they just have to be level matched and crossed over similarly, which is pretty simple.
    To the OP: if you played a wave sweep, I would bet that with your one sub you would witness from the listening position the bass get louder and quieter as the frequency changed. This is do to room modes, nulls, etc. A second sub in a different location will have different points where the volume comes in and goes out. The point of using them both is so that you benefit from the overlap. The low points on the on one sub will likely not be the same frequency as the other sub and so the two exhibit a smoother frequency response. Additionally, Pressurization is much easier to achieve and allows for more headroom. The two subs are sharing the duty of moving air and the less a driver has to move to achieve a given level, the better. (I am speaking simply and generally here, of course)
  • newrival
    VR3 wrote: »
    I wholly disagree. Those numbers don't account for room gain, and you don't know what levels the OP is achieving nor listening at. It may be true, but without measurements, that advice is just a stab in the dark
  • dorokusai
    I'm not sure why you're surprised Newrival? I based the comments on what he asked unless I missed something later. I would not try to integrate two subwoofers from two different manufactures, even if they are close in spec....which in reality of hearing both of them, they are NOT. Unless you want to arbitrarily wing it with the rear panel connections on the back, and the use of the AVR for the rest using some rough room correction preset guidelines, well, by all means go for it.
    It's certainly possible and it's been done here and elsewhere but you're commenting as if you know his room, current sweeps and all kinds of information based on his few posts.
    I don't see any reason to not simplify, use the better subwoofer and if you want to and are so overwhelmed to use both, get some real room correction subwoofer device to work all that out....again, which will be interesting to do if you can't even make the decision of what subwoofer to keep in the first place.
    I mean no disrespect to the original poster but I'm trying to keep it reality based and not toss advanced level room correction, a possible new device and expense and some frustrating time spent on this forum and perhaps others trying to figure out why it doesn't sound good or why at 40hz his wife accidentally craps her pants at 6pm every night.
    I'll just drop out and let you two sub experts rock and roll since I'm out of my mind I guess.
    Good luck.
    Mark
