Nice Classic Harmann Kardon HK 670 60 watt /ch AM/FM receiver 1979 SERVICED
geppy1
geppy1 Posts: 3,076
edited August 2012 in For Sale (FS) Classifieds
Very nice Harman Hardon HK 670 AM/FM receiver from 1979. Probably one of the 3 best receivers they ever made. This features 60 watts per channel of high current and has not problem driving low impedence loads. The sound quality is superb with a huge stage. I have had 3 of these and really like them but i need to stick with my HK integrated for now. It works perfectly and needs nothing.as it has been completely serviced. It is in very nice shape but there are some scratches on the top surface of the faceplate. The AM rod is also broken off. The A terminals have been updated for use with bananas but the originals will be included. The original power cord as been repaired as I use a detachable with my gear. The previous owner( a tech) did the following.
*Replaced ALL electrolytic Capacitors with the exception of the 4 Main Caps using brand new, Nichicon audio grade caps.
*All transistors mounted to heat sink were removed, cleaned, replaced heat with New sink compound and re-attached.
*Re-soldered weak and flat out Bad solder joints, particularly the Pre-amp and AM/FM Tuner boards.
*Lamps replaced.
*Cleaned all switches and pots with De-Oxit Cleaner, Then, 12 hours later, went back over all switches and pots and used De-Oxit Fader Lube.
*Used De-Oxit D100 on the Tuner Pivots to clean and remove tuner rumble.
*Set the Power Amplifier idling Adjustment to Factory Spec.
*Set the Output DC Voltage Zero to Factory Spec.
Asking $139 Thanks,KG
60 watts watts min. RMS per ch, both driven @ 8 ohms
Power Bandwidth: 8Hz-100kHz @ < 0.08% THD @ 8 ohms both channels driven simultaneously
Total Harmonic Distortion: 0.03% 1kHz at rated output
Intermodulation Distortion: 0.05% at rated output
Frequency Response: Below 3Hz - 140kHz -3.0dB FM - 20Hz to 15kHz +/-0.5dB
Damping Factor: > 30 at 8 ohms
Hum and Noise: PHONO - -90dB "A" weighted, IHF
Aux & Res - -102dB "A" weighted, IHF
Slew Rate: 65V/usec
Rise Time: SQUARE WAVE - 2.5usec at 20kHz
Square Wave Tilt: <2% at 20Hz
Negative Feedback: 28dB
Sensitivity: PHONO - 2.2mV HIGH LEVEL - 130mV
Phono Overload: >225 mV
Input Impedance: PHONO - 47k ohms
Usable Sensitivity: FM MONO - 1.9uV
Quieting Sensitivity: MONO - 3.0uV STEREO - 30uV
Signal-to-Noise Ratio: FM - -75dB Capture Ratio: 1.2dB
Alternate Channel Selectivity: -75dB Image Rejection: -80dB
IF Rejection: -110dB
AM Rejection: -62dB
Stereo Separation: 55dB at 1kHz
Distortion: FM MONO - 0.05% at 1kHz, 100% modulation
FM STEREO - 0.08% at 1kHz, 100% modulation
AM Section Sensitivity: 300uV/meter Selectivity: -40dB Alternate
Channel Selectivity: -35dB
Image Rejection: -50dB at 1kHz
IF Rejection: -45dB at 1kHz
Dimensions: 440 (17.32 wide) x 163 (6.5 high) x 398mm (15.6 deep)
Weight: 30 lbs
023.JPG 485.7K
024.jpg 591.1K
026.jpg 399.7K
027.jpg 408.9K
028.jpg 511.2K
030.jpg 476.7K
Post edited by geppy1 on
  • bookshelf^love
    bookshelf^love Posts: 10
    edited August 2012
    Hows the Grounding on the amp? With some of the late 70's and early 80's Gear ive had some bad luck with Harmonic distortion.
    mhardy6647 Posts: 35,397
    edited August 2012
    The hk670 is an uncommon and very good piece of hk hardware. TOTL receiver of its time; twin powered as well I believe (separate L and R channel power supplies). It is very low in harmonic and intermodulation distiortion, and reflects hk's (and designer Matti Otala's) focus on broad, flat frequency response and excellent transient response as significant parameters in high quality amplification.
    http://otala.com/pages/mao/
    The manual is available from hk at:
    http://manuals.harman.com/HK/Owner%27s%20Manual/HK670%20om.pdf
    couple of interesting and more-or-less relevant threads on this fine receiver:
    http://www.audiokarma.org/forums/showthread.php?t=44567
    http://www.audiokarma.org/forums/showthread.php?t=463229
    This is, I'd none-too-humbly opine, a terrific vintage receiver as described for the asking price.
  • wdrazek
    wdrazek Posts: 4
    edited August 2012
    Hi, I bought one of these when they were new in the day... where are you located?
    Wayne
  • geppy1
    geppy1 Posts: 3,076
    edited August 2012
    MN Shipping is not an issue. KG
  • Dabutcher
    Dabutcher Posts: 2,618
    edited August 2012
    I had the HK730 twin power. And it was the best piece of gear I owned for a long time. Just bought the Nad from this man. Stand up guy with great gear. Nad sounds awesome w my EV studios. GLWYS. Darryl
    edited August 2012
    I have both a 430 and a 730. I suppose the caps should be upgraded in the 730 because the lower model has a 'sweeter' sound. A pair of Dynaco A25s run on the 430 are nothing short of a vintage "rush"! You will swoon if you're a fan!
    Geppy's model above is heavier than a 730 and more powerful, it seems. It is also a Twin Power if I read the pic correctly (hard to see). If so, that's a great price for this model, not that the gepster needs any help here. Everything I've gotten from him (as Dabutcher says above) has worked perfectly!
    HKs have a nice warmish sound to them, especially these earlier units. As mhardy informed me, many who run vintage Klipsch love these units for what they do with "horns"!
    GLWTS!
    cnh
  • geppy1
    geppy1 Posts: 3,076
    edited August 2012
    BUMP Need to move this unit
