1st Order and Crossoverless Speaker Designs
parimento1
parimento1 Posts: 15
edited August 2012 in Speakers
What are the pros and cons of these designs? I know Thiel uses 1st-order networks exclusively and Anthony Gallo uses no crossovers in many of his speakers.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    Dont know about thiel but gallo has never used crossovers in his wine.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Face
    Face Posts: 14,340
    edited August 2012
    Unless the speaker has drivers specifically made for shallow slopes, they can sound pretty horrid. Tannoy and Thiel have drivers made for these specific applications. But if you saw a Thiel crossover, you'd be shocked to see how many parts they do indeed use...
    Just curious, why do these designs interest you? The average(not Tannoy or Thiel) 1st order/crossoverless speakers have high levels of 2nd order distortion. Which isn't offensive like 3rd order, but adds colorations and sound similar speakers made 30+ years ago, before the golden age of measurements and speaker crossover design.
  • halo71
    halo71 Posts: 4,645
    edited August 2012
    They interest me for their simplicity. And the fact I've never heard any. Something like these Hemp Acoustics would be a nice place for someone to get their feet wet for $100/pr. Maybe?
    http://losangeles.craigslist.org/lgb/ele/3213838340.html
    "These speakers are a project of mine from a few years ago. They use a Hemp Acoustics 8" full-range driver in a bass-reflex cabinet. No crossovers are used or needed. Great speaker for the audiophile or hobbyist to tinker with. With a little EQ they sound very good with lots of detail and good imaging. They are very efficient and require very few watts to sing.
    I also have a little T-amp I can sell with these for a few more bucks.
    Moving so need to sell soon.
    Email me any questions. Thanks!"
    --Gary--
  • Face
    Face Posts: 14,340
    edited August 2012
    If you don't mind a very small sweet spot, go for it. They can sound nice with certain kinds of music.
  • DollarDave
    DollarDave Posts: 2,575
    edited August 2012
    Vandersteens use a first-order x-over. I suggest an audition of a couple of their models.
  • zingo
    zingo Posts: 11,258
    edited August 2012
    Some of the Heritage Klipsch also use 1st order. I'm running a modified Klipsch Type A crossover right now on my corner horns, and they sound great; the XO uses only one inductor, two caps, and an autotransformer. However, on the same speakers, I've heard that the ALK extreme slope crossover also sound very good, and those crossovers weight about 20lbs a piece.
    It's all about the interactions between drivers, frequency response, and what you are try to achieve. I know that since Focal manufacturer all their drivers to the specs they want, they tend to use smaller crossovers because they don't have to correct or adjust for unwanted driver responses from third party manufacturers.
