HK 3390 stuck in standby
cwsmith68
Anyone in here have any experience with the HK 3390 being stuck in standby mode? I bought this unit as an open box sale for nearly nothing with all accessories in original box. I plugged it in and it powered on but after a few seconds went back into standby and now will not power back up.
Any and all help and advice is appreciated
Thanks,
Coley
Thanks,
Coley
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
Check all your speaker connections and make sure everything is OK. Power down unit, also turn off the switch on the back of the unit if there is one. Wait. Reconnect power cord. Turn on Back power switch. Turn the unit on with remote or front button. Make sure Speaker A or B is selected. Make sure TAPE MONITOR is NOT ON!
If none of that works. You have a repair on your hands.
