VM series
jimsvm
jimsvm Posts: 307
edited February 2014 in Speakers
Hi all, has the VM series been discontinued? If so how long will parts be available? Thanks
Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Post edited by jimsvm on
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    Contacted Polk, looks like i picked another winner, parts still around. What now?
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    Ps, just out of warrenty!!
    edited August 2012
    So what are you saying?
    Do you have a faulty speaker or two? If so, you've said Polk claims parts are available. So I assume they would sell you whatever you need for a repair, no?
    I don't understand where you're going above. Everything seems OK!
    cnh
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    All the speakers are ok. Sounding better time i lite them up? I think the sunfire is lossening the up. Very happy with them! I just do not to be 5 years down the road and no parts to be had. Better stock up now. Some good things do come to an end!!
  • teekay0007
    teekay0007 Posts: 2,289
    edited August 2012
    jimsvm wrote: »
    jimsvm, you sound like C.L.: "The sky is falling!! :exclaim: The sky is falling!!" And in this case C.L. is not Craigslist. In the future, as now with Monitor and SDA parts, I'm sure LOTS of VM Series parts will be available for those in need.
    Hey, why do you have VM30s as rears and VM20s as fronts? :confused:
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    It's the only way that would fit the application. Avr driving front and BOB takes care of the rest
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2012
    The VM series was really neat but I think it fell short in many areas unfortunately. I was never a fan and was not well received for my reviews of them when I did product testing and evaluation for Polk. Not every speaker is going to be a winner, even with the best intentions. What they do excel in is form factor, overall aesthetics and a very nice midrange when broken in. Break-in took a long time and was the cause of more than one early criticism if you didn't give them enough time to loosen up. They often sounded just too thin and bass shy, which is a given to a point but they lacked the usual Polk punch unless you had the VM30.
    Anyways, like you said, you should grab some spares but I wouldn't go freaking out just now. Spares should always be a consideration in any used or discontinued loudspeaker.
  • gdb
    gdb Posts: 6,012
    edited August 2012
    I have a never used, VM-20 in silver, PM me if you're at all interested in it.:wink:
  • JuanR
    JuanR Posts: 718
    edited August 2012
    gdb wrote: »
    gdb..yoour mailbox is full :)
    I'm interested....
    send me a PM with price shipped to 60617....
    Juan
  • dorokusai
    edited August 2012
    gdb wrote: »
    The Polk ones? That reminds me that I have a pair out to Jstas that are actually mine, so I should get them back.
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    Thanks dorokusai, cooler heads will prevail. Honey turn down the volume!! Lol let me know if you want to part with them.
  • dean.collins
    dean.collins Posts: 3
    I'm after a pair of black Vm30's if anyone lives near NY 11201 and looking to sell.
    My contact details are on my website at www.collins.net.pr
