DIY Speaker Cables Take 2
stangman67
stangman67 Posts: 2,328
Hey All,
Building boutique style cables has become quite a hobby of mine. About a year back I built these cables using some basic belden cable and some sheathing and bananas. They turned out great and are being utilized in my HT setup with my LSI15's and LSC.
Now that I am putting together a simple bedroom 2 channel setup, I decided to build another set, but go a little further than my first set. The equipment in this setup will be a squeezebox touch, an Emotiva Mini X a-100, and some polk monitor 40's for now. I started the cables with some Canare 4s star quad wire, some viablue sheathing, viablue splitters, shrink wrap and some awesome GLS locking bananas. Unfortunately I didn't get sent the correct amount of sheathing so I was only able to complete one cable today. More is on the way.
The process is as follows if anyone wants to replicate what I did.
Start by feeding the wire through the sleeving and taping it off where you want to split the wires.
After cutting the sleeving, and cutting the wire stuffing, twist the pos and neg wires as shown.
Then put shrink wrap over the wires and shrink it down a bit.
Then install the splitter which is quite self explanatory so I won't go into detail.
After the splitter is installed, strip the ends and finish the heat shrink. And then terminate as you choose. I highly recommend these GLS bananas.
And one completed cable!
In the end I think the cable turned out great, and look much nicer than my first set. In the end I will have invested right around 100 for both cables, and I certainly got the boutique look I was aiming for, as well as the great sound of the Canare wire. Let me know what you guys think.
Post edited by stangman67 on
  • halo71
    halo71 Posts: 4,637
    edited August 2012
    Very nice! Great looking cables. Now the test, send them to me for review! :cheesygrin:
    --Gary--
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited August 2012
    Look'n good! Nice Job!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • whitecamaross
    whitecamaross Posts: 219
    edited August 2012
    damn man you got skills... wow..
  • whitecamaross
    edited August 2012
    stangman67 wrote: »
    Hey All,
    how long are these?
  • whitecamaross
    edited August 2012
    how long did it take you to make these?
  • stangman67
    edited August 2012
    Thanks guys. @Camaro, I don't have any crazy skills, just some patience and a goal! That is all it takes, same as with any DIY project. And they are 7ft each, each one takes me about 30 minutes from start to finish. I like to take my time
  • whitecamaross
    edited August 2012
    how fast is that stang of yours?? i have a camaro ss that would love to run lol
  • stangman67
    edited August 2012
    It's pretty quick. It's a 67 coupe, Keith Craft Small Block, Tremec T-5Z tranny. I'm guessing yours is a late model, so I'd be toast. It's quick but most modern muscle will kill it
  • whitecamaross
    edited August 2012
    mine was a 1999, but sold it to buy a c5 z06. however, that one is also gone lol
  • halo71
    halo71 Posts: 4,637
    edited August 2012
    Wish I still had my first car. A '71 Camaro.
    --Gary--
  • gp4jesus
    gp4jesus Posts: 2,019
    edited August 2012
    I see you doubled up your "run?" What's the final gage? 10? 12?
    *all connected w/Premiere ICs
  • stangman67
    edited August 2012
    Yea I did. It's a star quad wire and I have no reason to biwire my speakers. The wire diameter of each is 14 so that makes final diameter equivalent to about 11 gauge.
    EndersShadow Posts: 17,713
    edited August 2012
    @ Stangman its probably closer to 10 since with stranded wire you cant ever really get rid of all the air pockets in it :smile:. Really cool looking wire. Been planning on making my own for a long time just waiting on the funds to come through which they should on Friday :smile:.
  • vcwatkins
    vcwatkins Posts: 1,992
    edited August 2012
    Thanks Stang for posting this. Bookmarked this thread so if/when I get the time I can give it a shot.
  • blairfrischx
    blairfrischx Posts: 259
    edited August 2012
    The 4S11 is definitely a solid cable for making your own high-quality speaker cables on the cheap. Blue Jeans Cables sells it, if anyone is interested. I've looked into it in the past, and it is hard to find in an unterminated form on eBay. :rolleyes:
    Anyway, great cables, stangman. I've been wanting to make my won set for a long time; I've just never quite gotten around to it.
  • stangman67
    edited August 2012
    Yup, blue jeans is great and I generally buy my stuff from them. This time around I ordered from Martertek just because of the closeness to my current location. Great service from them
  • rvito
    rvito Posts: 11
    edited August 2012
    Very nice cables !
  • mesquitehead
    mesquitehead Posts: 312
    edited August 2012
    Here is a guy who lives near me in Austin that has all the needed components to build your own at reasonable prices http://www.douglasconnection.com/
    Great work my friend!
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • rebuy
    rebuy Posts: 694
    edited August 2012
    I guess it all depends on what reasonable prices means, I sure did not see any reasonable prices on the douglasconnection website.
    edited August 2012
    rebuy wrote: »
    My assumption would be he was refering to buying the connectors and wire from him to build your own. Also this is a fellow Polk members site (helipilotdoug) so buy with confidence.
    He's got good stuff and I know a couple folks very happy with his cables.
  • mesquitehead
    edited August 2012
    rebuy wrote: »
    Try the DIY section.:biggrin:
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
