EL34 Mono Block Amplifiers
doctor r
Shanling SP80 EL34 based monoblocks. 50 watts each. $700.00 (negotiable)
These amplifiers also have built in preamps (presently bypassed) that link together and enable a single remote (included) to control both amplifiers and sync volume. These were my primary amplifiers for 3 years and I beleive I am the third owner. Included in the sale is the remote, two quality power chords, bias adapter (fixed bias), 4 SED EL34s, 2 Sylvania 6SN7s, 2 Sylvania 6SL7s. The sound is open, fast and articulate with just a touch of tube sweetness. They produce a beautiful 3D soundstage.
I used them with a separate external preamp, but they can easily be reset to use the internal preamps if a single source is contemplated. 8 ohm and 4 ohm speaker taps.
I do not have the original boxes and due to the weight (80 lbs combined with accessories) I would like to make these available for pickup in North Florida (Jacksonville) or I will be traveling to the Atlanta area over Labor Day weekend.
Specifications:
Rated output power: 50 Watts RMS @ 8 Ohms
Total harmonic distortion (THD+N): < 0.1%
Frequency response at rated power: 20Hz- 30kHz +/- 1db.
Load resistance: 4-8 Ohms.
Signal to noise ratio: >90db.
Input: RCA
Mains power: ~100V ? 120V @ 60Hz.
Line fuse: T2.5 Amp @ 250V A C.
Power consumption: 400W Max.
Dimensions: (mm) 205 W X195 H X 460 D.
Net weight: 15 kg.
Below are some reviews (with pictures), though mine are stock and have not had any of the modifications one review references. I will attempt to get pictures of mine loaded tonight. They are in very good condition except one of the posts has about a 1 degree difference vertically than the other corner posts. Not really noticeable unless you look for it. I will give them a 7/10 for that post, but in reality they look like an 8 on the audiogon scale.
http://www.stereotimes.com/amp070704.shtml
http://www.6moons.com/audioreviews/shanling2/80.html
Specifications:
Input: RCA
Net weight: 15 kg.
integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter
rack Adona Eris 6dw
Post edited by doctor r on
I like. price is for the pair? when will you post pics.. any trading?Hello Kitty am/fm CD player
Pictures as promised. The price is for the pair to a forum member. These are an excellent entrance into the rabbit hole for someone daring to venture to the tube side of the world.
Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.integrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
How close are you to haines city, my parents live there, maybe i could arrange a pick upHello Kitty am/fm CD player
should do great service to single driver speakers.Abbas Tube USB-SPDIF Converter with tube clocksAbbas V2 SE Tube DACAltmann Attraction DACNon-Pre passive preampYamaha M2 AmplifierDIY TPA3255 Mono Amps6L6 Williamson amplifier42 SET amp6V6 SET ampMcIntosh XRT18 speakersApogee Centaur MinorPioneer PAX A30 speakers
PM sent onebadchadintegrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
I want, I want, I want.. im working on it~Hello Kitty am/fm CD player
Shameless bumpintegrated w/DAC module Gryphon Diablo 300
rack Adona Eris 6dw
