Sealed Enclosure
Systems
Hello i would like to know if there is a program of which i could design a simple sealed enclosure for 4 mm2124 subs that require .88 cubic feet
Testing
Testing
Testing
Testing
Testing
I just want a simple cube shape so it can fit into a jeep cherokee also i would like to use 3/4mdf on all of it then 1inch mdf in middle and then fiberglass resin on the inside of every chamberTesting
Testing
Testing -
Kim's gonna need some maximum dimensions for the box in order for him to be able to give you measurements. Just find out what's the highest, deepest, and longest the box can be and still fit in your Jeep, then he'll be able to calculate the dimensions for you."The Big C"
MTX.com and go to "education". there is a weathe of knowledge on how to build enclosures.Testing
Testing
Testing
