Moving from an Onkyo 5.1 to a 7.2 (Power Question)
tophatjohnny
tophatjohnny Posts: 4,189
edited August 2012 in Electronics
I am upgrading from the Onkyo NR 414 to the HT RC 360 (I know not a huge upgrade) but question I have is, when I am only using the new receiver's 2-sub outs and HT-2000i towers and a pair of FX 300i's and a center (5,2 set up) am I losing out on power by leaving the other speaker outs empty?? I am hoping to gain some Oomph by changing to the 100W over the current 80 Watt, and the fact that the new receiver allows for an additional amp down the road, so I am hoping to gain that Oomph and cause no harm to the unit by only using the speakers I have. No plans at the moment to add more speakers as I love the sound I have....just want more power when listening to my music. Any thoughts??
Post edited by tophatjohnny on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited August 2012
    I thought the response you got here was on the mark. No, you're not "losing out" by not connecting 2 speakers. In fact, you're further dividing the available power when you connect more. As suggested, a receiver with pre-outs is a good idea. This allows for the addition of external amplification later - never a bad thing, imo.
  • tophatjohnny
    edited August 2012
    mdaudioguy wrote: »
    Thanks and when I asked that question, I thought I had 85 watts in the 414 and it is only 80. The HT RC 360 does have the pre-outs and with the additional 20 watts, I hope it will drive my music up some. I will be on the hunt for a amp before too long, but that will be another learning curve for me. Fingers crossed.
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2012
    The Onkyo HT-RC360 doesnt have analog pre outs. It only has them for the sub. You have to get a Onkyo HT-RC370, or Onkyo TX-NR7xx or greater reciever to get analog pre outs so hopfully you havent bought the RC360 yet.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • tophatjohnny
    edited August 2012
    jbooker82 wrote: »
    Yes I did order it. The sales guy at Accessories4less.com clearly said I could add a power amp down the road?? I wont be delivered until Tues, in which I guess I will just refuse shipment or have them send me a return label. Now I am mad...more at myself for not asking here before I jumped out the window. guess I'll be eating the ship charges????:frown:
    edited August 2012
    Lesson learned, do your own research by a simple google search.
    As stated, it doesn't have preouts, nor will you likely notice a difference between 80 and 100 watts. If you have limited funds to purchase a new receiver, may I suggest a used one would save you alot of coin. The pioneer elites used run around 300 -700 and offer all the current gizmos and beefier power than most. Good luck to you.
    edited August 2012
    Here's a good example of what little coin can buy.
    http://app.audiogon.com/listings/yamaha-rx-a700bl-aventage-7-2ch-receiver
  • tophatjohnny
    edited August 2012
    Thanks, and out of fairness to the sales person at accessories4less.com the seller wasn't hearing what I was asking for in the phone conversation. Trying to stay with Onkyo as they seem to hook up easy. Thanks Tony.
  • rebuy
    rebuy Posts: 694
    edited August 2012
    If you keep the current 5.1 config over the 7.2 your 5 speakers will be getting more power than if you connected 2 more. When you connect more speakers all around power falls to all speakers.
  • tophatjohnny
    edited August 2012
    jbooker82 wrote: »
    Okay, I found a TX NR 708 refurbished one year warranty for under 400.00. I see a spot on the back that says Analog pre-outs so I sure hope this is the one for me?? I have it held in a cart right now and hope to hear back from someone soon?? Thanks
    edited August 2012
    Not trying to steer you away, but all receivers hook up the same way. Don't understand that statement unless you care to elaborate on it. Aside from that, good luck to you on your search.
  • tophatjohnny
    edited August 2012
    tonyb wrote: »
    Thanks Tony, I just had trouble with a nice Sony receiver and got frustrated as heck. The few Onkyos have all been super easy to hook up. Thanks
