Two 12 inch drivers, 2 plate amps (400@ 8 ohm) same cabinet?
SDA1C
Not being any type of sub guru....I wonder if it would be more effective to build a two chamber box with separate enclosures, that is one box with two separate enclosures, or one shared enclosure with 2 drivers and 2 amps. I have put some serious thought into the Decware housewrecker. If there are any suggestions I am all ears I like the Idea of balance with one 12 on each side of my 1c in the theater but performance is always paramount of course.
Too much **** to list....
Post edited by SDA1C on
Put them in separate enclosures and in different places in the room for flatter bass response."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
crap....i figured that would be the answer. and the take on the house wrecker?Too much **** to list....
Looks like a generic box, I'd look elsewhere."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Listen to "Face" he speaks truths about seperate enclosures and better bass resp, and you'd be best to build your own enclosures specific to the sound you would like and to where you will locate them, itl be worth it, plus youl have better satisfaction of building it your self, why buy something somebody else thinks sounds good? Build something YOU know sounds good
