Need advice...
Tcuguy
Tcuguy Posts: 2
edited August 2012 in Speakers
will a 22x4 rms kenwood headunit have enough power to push a pair of Polk Audio DXi690's. This set up is going on a custom made smoker bbq trailer i'm having made and will run off a deep cell battery. I'm trying to avoid using an amp as they drain the battery quite a bit faster than using just a headunit. Question is, is 22 watts rms enough to push these speakers, or is there going to be a lot of distortion. Could always drop down to the 6.5's or the 5 1/4's, as they require less power, but i feel you loose a ot of base.
Thanks in advance....
    EndersShadow Posts: 17,753
    edited August 2012
    For what your doing you should be fine, however if your looking for more than background noise in an open air enviornment just about all those speakers will really need decent power behind them to give you anything other than background sound.
    Now if this is more to listen to games while tailgating I would think you should be fine.
  • stretchl
    stretchl Posts: 1,334
    edited August 2012
    Hope yer pushin some Skynard outta that bar-bee-cue trailer, big guy...
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited August 2012
    I would look for the most efficient 4 ohm speakers I can find. Don't have to be car audio either.
  • Tcuguy
    Tcuguy Posts: 2
    edited August 2012
    Need to be marine speakers so they can hold up.
