Onkyo 806 - Karma
bklynNupe
It needs some repair. The unit powers on and works sometimes without issue, however recently some of the channels would drop almost like there some sort of short? I had to rerun the Audussey a couple of times. It worked but the issue would shortly return. I would imagine some out here could fix it. I would not have a clue, besides I wanted to try something else. This is why I'm offering it for free to a fellow Polkie. I would really prefer pick up. If absolutely necessary, I will ship from my local post office at the receiver's expense. I have everything it came with including the original sturdy box, instructions, remote and set up mic. The receiver is being offered with everything, I don't want to give it away piece-meal.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
Post edited by bklynNupe on
I'm interested, how much to ship to Queens? I can also pick it up since you are in Brooklyn.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Man I knew I should not have left this until after dinner, oh well, besides I'm not local.
Serendipity wrote: »I'm interested, how much to ship to Queens? I can also pick it up since you are in Brooklyn.
I prefer a local pick up but if no local takers, I would be willing to ship for actual cost.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
I can do a local pick up as I am pretty much a short hop away from the Grand Central and BQE.
If there are no other takers, I can fix the unit.polkaudio RT35 Bookshelves
Sweet deal, I have an 806 and it is a quality unit. If it didn't cost much for the repair, it could be a real score for whoever gets this thing.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Got back home with the unit. Thanks Brad!
Just a few observations while testing: The unit seems to function fine in 2 channel mode but immediately goes into protect when a surround mode is selected and the volume is turned up. Without tearing it apart, I guess most likely a bad FET on one of the surround channels is shorted and taking down the unit.
It works in Stereo mode though, not a problem yet.polkaudio RT35 Bookshelves
good to know it may be salvageable. Keep me posted on how it turns out.Serendipity wrote: »Got back home with the unit. Thanks Brad!
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
Power supply section looks good so far. Has a shorted part in the output stage, just need to do some troubleshooting to find out where and which channel. It's been playing fine in Pure Audio (2 channel) mode for the past few hours, so I doubt there is anything wrong with the L/R.
Was this always connected to an external amp or was it powering your speakers at some point? I forget..polkaudio RT35 Bookshelves
Unit is currently working in 5 channel mode. When the Surround Back speakers are enabled, the unit goes into protection mode. I'll have to change 12 transistors to get the unit back to working order, but it works fine powering 5 channels.
[video=vimeo;47400753]https://player.vimeo.com/video/47400753polkaudio RT35 Bookshelves
Just a friendly reminder -
After taking this unit apart and looking at the design, it seems that this receiver wasn't really designed to run cool or have a long life. The output transistors are very close to each other, and the HDMI board is right on top of the unit taking up all the heat from the other components. For those of you who own this unit, I recommend keeping it in an open space - not inside a cabinet - and letting it vent directly into the room. This will help to prolong the life of the unit as they sure do run hot!polkaudio RT35 Bookshelves
