Surroundbar 50
Kev7274
Does anyone know what gauge of wire the speaker harness uses? I need one,but then I was think I have some 14ga lying around. I like the idea of all the wires as one,so trying to decide to either buy the harness or just use my 14ga wire.Thanks
Post edited by Kev7274 on
14g will work fine and fit inside the binding posts. The supplied harness is simply convenient but there are a number of users here, including myself that use larger gauge and much better cable. As with anything, you can go crazy.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks. I figure I could just cut 5 lengths of wire to hook it up since I already have the wire. Run is around 6ft.
16 gauge is best
Thanks for the replies. I ordered some Canare cable yesterday.
