Speakers for my H-D
troop
Hi All,
As you can see, this is my very 1st post :cheesygrin: I'm looking at some Polks to install in my batwing fairing and want some input as to the sonic differences. The system is a JVC deck and Arc Audio 75w x 2 amp. Current speakers are Memphis Audio MClass 6.5" components. I like them ok but just looking at something different. I think I've narrowed it down to the MM651 or MM6501. I do have holes for tweeters so components work fine. Is their much sonic difference between the the two? Not concerned so much at a standstill but about going down the road at 60+mph with wind, road and exhaust noise playing into the mix. The MM651's can be found for quite a bit less and the crossovers are a bit smaller so they sound favorable. What if I throw the DB6501 components into the group? Cheaper still but probably not as durable for m/c use. The lower impedance MM line should really rock! Knowledgable input appreciated for the newbie.. Thanks !!
