Need help with a car electrical issue
ryanjoachim
ryanjoachim Posts: 2,046
edited August 2012 in The Clubhouse
I have a 95 Buick Century. It runs great, and only has a couple issues. No AC, and the motor for the window on the drivers side need replace, but I'm not too worried about those.
One that has got me frustrated is the illumination on my dash (that comes on at night). When the night-lights come on, everything on the dash and radio turns off. The radio still works, the indicator lights still work (blinkers, check engine, etc) but none of the ambient lighting works.
I've swapped fuses 4 times. Twice with 5's, once with 10's, and tried both a 15 and a 25.
The 5's and 10 both blew within a few hours of use. The 15 and 25 wouldn't even work.
Any ideas?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2012
    Sounds like a bad ground. Where I couldn't tell you, but clean / unplug re-plug anything that looks dirty.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Jstas
    Jstas Posts: 14,978
    edited August 2012
    Is it an aftermarket radio or has the radio ever been removed from the dash and put back?
    If yes to either question, you probably have a pinched lead grounding out. Or something like a dimmer lead on the head unit is wired incorrectly.
    If no, you probably have a bad lead worn through some insulation or something that is grounding out.
    Expert Moron Extraordinaire
  • tonyw
    tonyw Posts: 21
    edited August 2012
    If your blowing fuses, you gotta short, don't replace with higher values unless you wana fire in your dash as your crusin down the road! But yea like guy said check your deck wiring, and if its an original stereo check the wiring anyway! Odds are its been replaced before and wirings prolly chopped up and shorted, if that ain't work geta schematic and a volt meter
  • gdb
    gdb Posts: 6,012
    edited August 2012
    Yeah, bigger hammers and bigger fuses are seldom the answer to a problem.:wink: (frequently enlarges the problem)
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2012
    I had a the light for the ashtray that had came out of the socket and part of the wire was shorting out on the metal part underneath the dash. I kept blowing fuses and the dealer could not figure it out either I just happened to buy a new cigarette lighter and that is when I noticed it.
