Need some Power Amp/Preamp/DAC, PC 2.1 setup, advice please!
wxcarne89
wxcarne89 Posts: 20
edited August 2012 in 2 Channel Audio
Hello, I really could use your guys opinions on my situation here. any help would be appreciated.
So i've been working on building a 2.1 system with only one digital input coming from my (early 11, 15.4") macbookpro's mini toshlink port. I just purchased a Emotiva XDA-1, originally I thought I had found the perfect solution. However I have just discovered the many complaints related to the lossy volume control. I believe many of you on these forums are experienced w/ this XDA?
I am planning to spend around $400 on a solid state power amp in the next couple weeks. I switch between amps using banana plugs. currently my system includes a Fisher 800B (tube) receiver, the xda-1, and temporarily a pioneer elite A35r. I am also still using itunes till I decide on a good value priced software. Lastly Zombieboy 2000 sold me a B&K pt3 preamp/tuner I purchased to use with my tube amp (FM/AM tuner in my receiver needs alot of work, and I wanted a sub out) but I could just use it, it just feels like an eleven yr old pre w/ a brand new laptop/dac/power ampwould be a waste.
So my dilema is that I want to use a power amp, coming from the outputs of the XDA-1 to keep things simple. However most of my listening is done at a low volume level, so I feel that this may be an issue. I currently don't plan to use any analog inputs, so I really would like to avoid spending hundreds of dollars on a preamp (such as the emo Usp-1) All my cd's were destroyed in a flood, and my receiver has plenty of analog inputs anyway!
So now that I have explained my situation, should I just use the XDA-1 as a DAC (Volume set to max) and control volume via (a new) media player,
Purchase an integrated (would prefer power amp),
Put off amp purchase and buy an expensive pre?
Im at a loss!
One last thing, any body know of any really nice power amps in the 400 dollar range. I am currently considering a Class D audio build your own kit, or an Emotiva Upa-200. I am not opposed to purchasing used or vintage either! I welcome any suggestions, thanks!!!!
New to the forums, and home theatre.
This will become my secondary system in the fall or spring, but it consists of:
Front: Polk Monitor 40's on 36" Bell-O stands
Front B: Klipsch F-10
Center: Polk CS-2
Rear: Polk Monitor 40's
Subwoofer: Klipsch Sub-12
Receiver: Yamaha HTR-6130
Cd Player: Kenwood Dv-605 dvd player to play data disks.
Macbook pro/External Blu Ray as a HTPC for media.
Post edited by wxcarne89 on
  • fbm211
    fbm211 Posts: 1,488
    edited August 2012
    Adcom 555
    Parasound
    Cary---My favorate.
    Try audiogon for good deals on used equipment
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • 11tsteve
    11tsteve Posts: 1,166
    edited August 2012
    i am just wondering what your issue with using an 11 year old pre-amp is if you are fine using a vintage amp? if it is a good sounding piece of gear and has what you need, i mean. and what speakers will you be driving in this system?
    i got my Parasound for $345 on Ebay. certainly enough current to drive my 11Ts. its not perfect sound, but warmer and i like it better than my previous Acurus 250 which was a bit brash.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • wxcarne89
    wxcarne89 Posts: 20
    edited August 2012
    For now I have a pair of monitor 40's by my computer, and on speaker B I have a pair of Klipsch f-1's. I'm still debating on building speakers vs. buying a used pair of speakers off of audiogon. I've been looking at new wharfedale 10.2's, HSU bookshelves, and SVS. Used speakers i've considered include Rega rs-1's, b&w dm602's, and similar, on audiogon. I live in an unfortunately bad area for auditioning speakers. Realistically I will likely use the B&K till after I've finished my amps, restored my tube amp, and upgraded speakers. For the time being I think I am going to work on building a set of Class D audio 125wpc amplifiers. I'm going to build them one at a time, as finances allow, and use them as monoblocks. I was I could avoid purchasing a pre, but it seems inevitable.
    Center: Polk CS-2
  • zingo
    zingo Posts: 11,258
    edited August 2012
