Threaded inserts on SRS's?
vcwatkins
vcwatkins Posts: 1,993
edited August 2012 in Vintage Speakers
I disassembled one of the recently purchased SRS 1.2's today to install rings, dynamat, and armacell. MW drivers are dated 11/87 to 3/88. All looks good, but I found something I haven't seen before. The drivers are held in place with ~1/8" x 1/2" hex drive bolts into threaded hex drive inserts. These are not hurricane or T-nuts. They seem pretty firmly attached - I couldn't pull one straight out, no leverage, with pliers on an inserted bolt. But they are flush on the inside and do not provide a wide flange for additional resistance. A couple questions:
- Was this the normal production method for '88ish or was this a mod done afterward?
- Will the effectiveness of this method approach that of the rings?
Thanks,
Craig
b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Post edited by vcwatkins on
    F1nut Posts: 50,754
    edited August 2012
    Factory standard.
    Yes.
  • vcwatkins
    edited August 2012
    Thanks!
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited August 2012
    They are terrible! when very firmly tightened they can deform the baffle are surrounding them. I pulled mine out and replaced with hurricane nuts. Though I haven't used them personally, I like the idea of the rings best.
  • vcwatkins
    edited August 2012
    Thanks Mr. B. I'm gonna do the rings, but will wait until I refinish/replace the wood and update the crossovers in the winter. I have a very good seal until then.
