Center and Surrounds recommendation to match my RT3000p's
jdustinb
jdustinb Posts: 34
edited August 2012 in Speakers
I'm currently looking for a cs1000p and some f/x1000's to fill out the system, but this has been slow going. Curious if anyone has any input on other speakers that I might be able to get my hands on.
Was looking at the RTi line-up - any thoughts on matching the RTiA6 and F/XiA6's with this?
Receiver is a Denon AVR-3312CI.
HT: Samsung UN55ES7100 | Denon AVR-3312CI | Polk Audio RTiA9 | CSiA6 | F/XiA6
Basement: Denon AVR-4800 | JBL Lancer 99 - Type E8-99 - LX4-1 crossover
On the hunt for: Emotiva XPA-2 | Outlaw LFM-1 Plus
Post edited by jdustinb on
  • jdustinb
    jdustinb Posts: 34
    edited August 2012
    :question: Anyone?
  • tophatjohnny
    tophatjohnny Posts: 4,182
    edited August 2012
    Wow, I am asking a similar question, so anxious to see if either of us gets a higher power to chime in here?? Sheeze???
  • 20hz
    20hz Posts: 636
    edited August 2012
    I saw on polks website a location where you add your drivers and it shows recomended matchs .
  • nwohlford
    nwohlford Posts: 700
    edited August 2012
    On the used market, you should be able to find a cs400 which is a match for that rt series. The cs350 is a nice center from the same basic era; there the 4 mids are 4.5", so they are not complete match.
  • jdustinb
    jdustinb Posts: 34
    edited August 2012
    20hz wrote: »
    Thanks, 20hz - I searched around and at least found a FAQ on matching the center channel up:
    http://www.polkaudio.com/polk-university/faq/what-center-speaker-matches-with-my-older-polk-speakers
  • B Run
    B Run Posts: 1,888
    edited August 2012
    The only center I would consider besides the CS1000p is the CS400, it would blend nicely and is still a great center. The surrounds don't matter as much but the f/x 1000's are really nice, but almost any of the fix's would work for surround duty.
  • tophatjohnny
    edited August 2012
    I did the FX 300i's as room is a factor and I'm sure they'll do the job nicely.
  • jdustinb
    jdustinb Posts: 34
    edited August 2012
    Thanks nwohlford/B Run. I'm curious then, you would recommend the CS400 over the CSiA6 then I'm assuming because of the timbre matching? I'm seeing some CS400i's are available, but none of the older non-i, which seem to have slightly different drivers.
