RTi10 to RTiA7 conversion
chriskriens
I've got a set of RTi10s that followed me through my college years and unfortunately don't look so good. I'm moving into my first home and would like to replace the cabinets and restore them to their original beauty. I've contacted Polk and they have cabinets available for purchase for the RTiA7.
Comparing specs, it looks like the drivers are all the same and I can just install the originals in the new cabinet enclosures. Is there anything that I'm not considering? Any subtle differences that would make this impossible?
I'm pretty sure the difference between the two is in the cabinets, so I say if you want to do it, go for it. One question though, is the price for the replacement cabinet cheaper than what you can find a good deal on for a used or clearance pair of A7's? If it is it really is a no brainer, if not you might want to just consider picking up a good used set of A7s.
Crossovers in the A7's may be slightly different. I found i10's a little brighter than the A7's. However nothing I can think of that would make the swap not work. Let us know how they sound when you're done.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
how much are the cabinets? i am sure they are not cheap.samsung un40eh5300
yamaha rx-a3010
oppo bdp-105
rtiA7, front
csiA4, center
rtiA1, front presence
rtiA1, surrounds
PSW 505, sub -
XO components & frequencies are different.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
