Monitor 5A vs 5B
skrol
skrol Posts: 3,450
edited July 2012 in Vintage Speakers
I have a pair of Monitor 5A w/ Peerless (1983) and a pair of 5B w/SL2000 (1984). There are things that I like about both but I need to thin the herd and am trying to figure which to keep. As most agree, the Peerless tweeters are sweeter than the SL-2000, however, I am not opposed to going RDO's in the 5B's. Which ever I keep, will get the XO upgrade. I like the bass of the 5B over the 5A but the 5A does seem to have excess Daycron damping material behind the PR's. I haven't played with removing some yet.
So, it boils down to 5A's w/Peerless (play with removing some Daycron) or 5B which would get w/RDO's. Any opinions?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
    heiney9 Posts: 25,432
    edited July 2012
    5B's with the RD0's and a x-over refresh and fuse bypass if your 5B's have a fuse for the tweeter.
    If the RD0 wasn't available I'd say stick with the peerless, but I think the cabinets and the later driver in the 5B's are just a little bit better.
    Just my .02c as you will have people equally commenting on both sides.
  • nhhiep
    nhhiep Posts: 877
    edited July 2012
    I am not sure how good the Peerless is but the new RD0 is really smooth compare to the SL2000 in my 1Cs
  • canadianicon25
    canadianicon25 Posts: 200
    edited July 2012
    i guess it comes down to which sounds better: the RDO or the Peerless?
    Both speakers could do with xover upgrades which puts that at par. As far as bass, if you think you are lacking the best thing to do is add a small sub and not quibble over small measures of bass output.
