HZ levels with mm2124s
Systems
Hello i like really low bass frequency i see that these mm2124s go down to 23hz is that low enough i also see that infinity kappa perfects go down to 18 will their be much diff between the two ?
Testing
Testing
Testing
Testing
Testing
From what I've heard, the human ear can only hear down to 20hz so anything below that would serve no purpose other then to, perhaps, liquidate your bowels.
But hey, if your constipated, it could be better then an ****.
You know, you really don't have to post the same question in every forum. If you are that impatient in waiting for a response, just call the Polk Audio and Infinity customer service phone numbers.Expert Moron Extraordinaire
