Ceiling mounting your surrounds
Early B.
Early B. Posts: 7,900
edited October 2003 in Speakers
Was wondering if anyone has their rear speakers ceiling mounted. I was thinking of doing that with my Rti28's. They're currently hanging by a nail on the rear wall about 2.5 feet off the ground. At this level, they inconspicuously melt into the room. I realize that's not ideal, but aesthetically, it wouldn't look right to hang speakers on the wall in our den any higher than they already are.
Recently, I was curious and aimed the speakers towards the sitting position. They sounded 10x better. Now the trick is to make it permanent while at the same time making it flow aesthetically.
Is ceiling mount a good option? If someone out there does that, what type of mounts did you use? Did you have to drill into your speakers to mount them?
"God grooves with tubes."
Post edited by Early B. on
  • thehalo8
    thehalo8 Posts: 127
    edited October 2003
    So how would hanging your speakers from the ceiling make them any less aesthetically than on your back wall? Now if you got the in-ceiling speakers installed thats a different story; maybe you should look into getting those for your surrounds.
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk TC60i's
    Sub: Polk PSW505
    Receiver: Onkyo TX-DS696
    TV: Samsung HLS 5687W 56"
    DVD: Sony DVP S5300
    Protection: Monster HTS 3600
    Backup Battery: Belkin AP3080010
  • Early B.
    edited October 2003
    thehalo8--
    My walls are made of beautiful judge's paneling, so I don't want to hang stuff on the walls themselves. There's also the WAF. to consider. In regards to getting in-ceiling speakers installed, I have no interest in doing that. There's no flexibility with that option.
