PSW110 turn-on thump
sponger
sponger Posts: 325
edited July 2012 in Speakers
Instead of leaving the sub in standby mode, I usually turn off the power strip it's plugged into. So, whenever I turn it back on, there's a major turn-on thump whether or not the receiver is already on or off.
Other than that, it works and sounds just fine. Would the turn-on thump be a good reason to let it remain in standby mode eternally? Or should I not even worry about it?
Thanks.
Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775
Post edited by sponger on
  • deronb1
    deronb1 Posts: 5,021
    edited July 2012
    Since you have plugged into a power strip, I would leave it in standby mode. Does it thump when it comes on in standby mode?
  • sponger
    sponger Posts: 325
    edited July 2012
    It does not thump when it comes on in standby mode. It's only when the power strip is flipped on. With the receiver, tv, and blu ray player already drawing standby power, I kind of wanted to avoid yet another 24/7 draw. If the turn on thump is not bad for the sub or the sub amp, then I'll probably keep switching off the power strip after each use.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
    F1nut Posts: 51,776
    edited July 2012
    Ummmm......yeah!
