Yep!
New job Karma.
26 1/2" tip to tip.
From scratch, 26 ga 6N OCC cryoed solid core copper with drain.
Pick a number between 1 and 125.
I will ship to Cananda but you have to pay the difference.
US and Canada only please.
Everyone is welcome as long as you are a member.
PLEASE DO NOT PICK THE SAME NUMBER TWICE.
1 Cable is 1/8th at the most, longer than the other.
Probably have another member draw next weekend sometime (or maybe tomorrow, better get that number in:cheesygrin:)!
26 1/2" tip to tip.
In with 57 "Hope I get a new job after 3 years without one" Karma replyComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
42
Very nice! -
In with 66 again!..
BTW Pep Congrats on the new job....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
In with 126Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Yes, "in", please... my dump-find Radio Shack "interconnects" (not to mention my motley DIYs) could use some higher-class company.
Fourteen (14), please. -
119 if you please sir.Congrats on the new job.Dan
Thanks #7Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Sure, let's go with 62.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
In with with 46..
Thanks!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Thank you pep...88.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
77. Thanks
New job as in these, or a new job as in 9 to 5? if its the 9-5 kind then congrats. I will take dangit brgman already took 126, Pep please put me down for 125 thank-youHome Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
48 thanks!!I got static in my head
The reflected sound of everything -
Nice karma Pep,
in please with 100 -
In with 11 please. Thanks pep!
99 Nice karma>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Thanks Pep! 26 please.
Very generous Pep . . . I'm in #111
TY,
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
13, thank you!
in please
numbers so far:
37
57
42
17
66
126<<<<<
24
14
119
7
62
46
88
77
125
48
100
11
99
26
111
13 -
I'm in 52 please.
Cheers
Roger -
27 please.
i'll take #332-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
In with 69. Thanks
dudeinaroom wrote: »13, thank you!
in please
numbers so far:
37
57
42
17
66
126<<<<<
24
14
119
7
62
46
88
77
125
48
100
11
99
26
111
13
Add
21
52
27
33
69
28
Put new numbers with original.Lumin X1 file player, Westminster Labs interconnect cable
In Please! I'll take 70
deletedLumin X1 file player, Westminster Labs interconnect cable
23 please, Thank You!SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
22 please. Thanks very much.
