screw taps vs. 5 way binders
leftwinger57
This is a continued thought about those Vanderseen 2ce I saw earlier today.I just remembered that the way to connect wire to these speakers is w/ a screwdriver and do the old wrap around. I was perplexed at this I know McIntosh does it w/ their amps but not so sure on speakers. The reasoning that was given to me was w/ wire only that's it 1 step and no deveice,no/ bananas,no 5-way no spade lug your adding 1 more piece that's not needed.Now, I do know how to splice ,trim and tighten wires but I thought the 5 way was the way to go and does appear on most newer high end speakers and also on lesser models the old spring tabs .. He also showed me that you had to make your own jumper if all the terminals were not used for bi wireing.
Ok, who's got the decoder ring?Political Correctness'.........defined
President of Club Polk -
Was there an actual question?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Mac hasn't used screw terminals since the early 90's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No just an observation....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I've got one more bowl of Captain Crunch to woof down before I can dig it out.HT SYSTEM-
