Amp or preamp for best impact
larry777
I have a Sansui AU-717 Integrated Amplifer that can be used as a seperate Amp or Preamp for 2 channel stereo. I was thinking about trying it in one of these configurations to see how it would sound. What would give the best results.....adding a Preamp or Power Amp ? Lets say a used preamp in the range of $500-$800 or a used amp in the $1000 range. If I started with the one piece I could always add the other later and use the Sansui in another room ( As it still sounds great ) I always wondered what seperates would be like.
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Post edited by larry777 on
I would get the amp first.
Good question! Won't know til ya try it.
What speakers will you be using, the Energy RC70's? I looked'em up, and, given the number of drivers, and the fact that they dip down to 4 ohms, I'd say they want some power! Lots of great choices for used power amps in the 1k range... even less. Parasound, Adcom, B&K, Rotel, Bryston, Krell, Classe, all have offerings in your range and less.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Yes I will be using the Energy RC-70's. I only play them up to moderate volume but a power amp will still likely make a difference. I was thinking about Bryston,McCormack ,Classe range of amps or something similar.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Van Den Hul Interconnects -
Any other comments would be great. Would anybody like to share their experience upgrading one piece at a time ?Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
That sansui 717 is a nice piece, give me a yell if ya ever want to give it up. As far as pre amp goes, gonna be hard in that price range to beat the Dared 2000a at 460 bucks. The amp section in that sansui is no slouch, but I'd look for a used B&K, Parasound, Belles, and a few others that can be had for under 5 bones.
After that...a speaker up grade for 2 channel would be on the list.HT SYSTEM-
lsi 9's -
I would go the amp route first. For a grand you have alot of choices.........
This is what I have done so far in my journey.
Started with an old HK AVR25 and my mirage fxr7 speakers
Added a Adcom 545 amp and used the HK as a pramp modified the mirage speakers abit
Upgraded my speakers from the mirages to a set of SDA 1B's
Then got rid of the HK AVR as the preamp and pickup up a tube preamp/dac
Then replaced the Adcom 545 with a Adcom 545 II that has been completely rebuilt with all new caps etc.
That is all thus far
I would start with a decent amp and go from there -
I would recommend first trying a tube preamp (see if you can borrow one) into the Sansui using it's SS amp section.
If you like the tube sound, and maybe spend some time playing with different tubes, you can then sell the Sansui integrated and buy a tube power amp or higher power SS power amp.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
Your Sansui is a very good vintage integrated. If you want to get into seperates I would sell the 717 and start fresh. Otherwise I would probably try a tube pre with it. I did try a Yaqin MS-12B with my AU517 and it sounded nice but not all that different from the 517 by itself.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
The Sansui AU-717 Integrated Amplifier is a very nice piece! just a re-cap and some bias and dc offset adjustments and it will be a killer integrated amp. other way if you want to get a new amp....I would go for a Bryston!!!Make it simple...Make it better!
Carver C-1 preamp! look it up."Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce -
I find the Power amp makes the bigger difference.
Personally I would get an amp, and pair it up with a good passive pre-amp. I like the Electra Print PVA myself, but the Luminous Audio Axiom pre is a great inexpensive alternative. Sell the Sansui to pay for the passive pre.
Regards
Mister Pig -
mister pig wrote: »Personally I would get an amp, and pair it up with a good passive pre-amp. I like the Electra Print PVA myself, but the Luminous Audio Axiom pre is a great inexpensive alternative. Sell the Sansui to pay for the passive pre.
Regards
Mister Pig
hey man how would that axiom compare to a adcom gfp-500II? I am running a 2 channel setup with phono, cd. it looks awesome.Adcom GFP-750
Adcom GFA-555II
Monitor Audio silver RX2
NAD T585 SACD
Technics sl-1200mk2 / ortofon m2 blue (signal cable/ Eichmann mod / Sumiko HS-12 Headshell
Jolida JD9 II / Mulllard Tubes
SignalCable Ultra speaker cables
SignalCable Analog 2 IC's
"ROMANCE WITHOUT FINANCE IS A DAMN NUANCE CAN YOU DIG I???" -
Classic Sansui gear the AU series is good stuff lots of people swear by them, I'am with Tonyb, if you ever decide to part ways with that 717 i'am interested, only if Tony passes on it.Home Theater
I have a Pioneer SA-9100 integrated that I once used in my main system. When I first tried seperates, I used the Pioneer as a preamp and bought a Crown DC-300A. It was a nice combination. I agree that the only way to know is to try your Sansui and give it a listen. I've used the Pioneer as a power amp also. The Pioneer is presently in my secondary system and I'm using it as an integrated. I still have the Crown also. I'm using that in my living room system...what a beast.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
+ 1 on the amp choice
go with amp first, the journey is a fun one though.
If only i new then what i know now,LOL.
