best back surround for a fx 1000
I have just got the fx 1000. I wanted to set up a 7.2. HT. what speaker can I use as surround back to best macht these speakers. I have A rti 7 as frond and a cs 400 as center. I have also a psw 12. I'm also lookin for a new sub. thx. Hurbo
Post edited by wilbert on
Anything with a tri-lam tweeter will match those, although they will not match your mains which have a different tweeter than the rest of your setup (which sounds pretty sweet by the way).
If you want something that matches the size of the fx1000s, then I would go with with with either the rt55 or rt55i, or the rt35 or rt35i. The rti25i would also work, but might be a little overwhelmed by those bad boys. The 25is will be easier to mount however...
Whats the budget for the sub?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thx for the reply. I can also got the rt3000 for $200,- Can I use theme as surround back. I don't want to get ride of the rti7. My budget for the sub is abou $500,-
Was that including the bas modules with working amps? Or just the sats? Either way not bad, but if its for everything that's INSANE! Yes, the tweets match so they will work just fine.
You have some good options for a sub at that price range (a LOT of options if you go used). But lots of the really good new options (like HSU, SVS, eD, etc.) will cost you 100-200 more for a real beast. There are lots of threads here about subs in that price range if you search around.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
no. that was not including the bas modules. just the sats. So you don't recommend a polk sub?
Which sub is the best to mach the fx 1000 and the rt 3000. I don't have the sub that comes with th rt3000. Can any one help me out. Do you recommend polk sub or other brand. thx Hurbo
