Connecting Amp to A/V Receiver
Silverfang2340
Hey all, I've been doing some reading lately of the benefits you're bound to get by connecting your speakers to an Amp vs an A/V Receiver and I think I'm going to go for the jump and get this Amplifier: http://shop.emotiva.com/collections/amplifiers/products/xpa2
However, I'm having trouble figuring out how I would get the amp hooked up to the receiver, I've read that you need to use the pre-out on your receiver but I don't get where it would connect to on your amp. Now, mind you I'm knowledgeable on connections such as LFE, RCA, HDMI, connecting speakers, etc, so I know some stuff. But if I connect the amp to the receiver via pre-out, how would I go about connecting my subwoofer as well? (preferred; LFE). The receiver I have is the Onkyo TX-NR717. Here's a picture of the back: http://www.hificorner.co.uk/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/t/x/tx-nr717__b__rear_n9999x9999.png.jpg
The amp will primarily be used for listening to music in 2 channel powering 2 RTi A7's.
Thanks a lot for any feedback as I'm new to amps completely and am unfamiliar with some of the connections it uses.
Current setup: Harman Kardon HKTS 30BQ
Next setup: Polk RTI A7's
Polk CSi A6
HSU VTF-2 MK4 12" SUB
Undecided on surround
Polk CSi A6
Post edited by Silverfang2340 on
Pre Out front into the amp useing RCA.
Ok, cool, thank you!Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Undecided on surround -
So basically, the amp would be powering the fronts and I would still be able to switch between sources on the A/V and still get audio (PS3, TV, CD, etc) Also, I'd still be able to use my sub connected to one of the Sub pre-outs on the receiver while the amp is being used, correct?Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Correct.
Great, and I'll assume if I ever get the XPA-3, I can just connect that amp to preouts center, and surround for 5.1 running from both amps.
Gotcha, thanks a lotCurrent setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Correct again.
Where are you from? The UK link has me confused.AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
Sub-Velodyne SPL-1000R -
Sorry, I just pulled up a large image from google lol. I'm from the USCurrent setup: Harman Kardon HKTS 30BQ
Polk CSi A6
